Open VI Reference source code is ok,but in exe not work
I use Open VI Reference in my source code is ok,but when I build EXE,it do not work,and show error.
What is the problem?
2018 64 bit
Here is the source code
here is the error from the EXE:
(1,779 Views)
VI's built into an executable have an extra level in their path definition.  I think that is what is happening to you.
Read https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019NFfSAM&l=en-US
(1,743 Views)
Thank you for your advise,but in my program I open the VI Reference by vi path,i do not use current vi path or other path.Just like this.It is a absolute path
(1,728 Views)
Hi AAA,
the error message mentions an "unexpected filetype": do you really try to open a reference of a VI file?
Can you attach that "untitled 333.vi" file?
(Btw. I hope you use some more descriptive filenames in your source code development…)
(1,714 Views)
Accepted by AAA0818
thanks for everyone:
the problem is find:
1,error:"unexpected filetype" may be my computor installed encrpytion software
2,In my program i uesd the  “Lock State:Set Methord”,However it do not available in the Run-Time-Engine.
(1,701 Views)
