Parallel acquisition at 25MHz with an PXI 7854R
For an application, I need to acquire a parallel bus at 25MHz with an 7854R.
I search for information on the forum and I am few lost. I saw that we can create derivated clock on my FPGA.
I can create a 100MHz clock and use it in a SCTL to check if a rising edge appears on my clock line and acquire the data line (24 lines of data) but I don't understand what the 40MHz limitation for the DIO means.
At which rates the data is refreshed if I used a SCTL cadenced at 100MHz to read a digital input?.
Do you know if it the best way or if it is possible to acquire my bus with this hardware?
Thank you in advance for your response
(2,396 Views)
Accepted by FJNI
The clock of the FPGA is 40MHz.  So that is the maximum rate of the inputs/outputs of the FPGA (Digital I/O).  What you could do is use a method node on the clock line to "Wait on a Rising Edge", read the data, and send the data out of a FIFO or DMA.  Put that inside of a loop and you should be good to go.
GCentral
(2,384 Views)
