Radio buttons all connected to property nodes
Hi RHutchings,
@RHutchings wrote:
As clear as I can say it, I have 6 textboxes that I would like to have hidden until I need to edit one.
Then why do you provide an example VI WITHOUT any textbox?
One possible answer to your requirement:
(German LabVIEW: "Optionsfelder" = radiobutton, "Sichtbar" = visible)
Message 11 of 25
(1,807 Views)
Of course it seems silly to only show the selected item, because how are you even going to select something else?
Still, this will do what you want (only make the currently selected item visible):
Of course you can easily change the property node to e.g. the "label visibility" or "boolean text" visibility. Same difference.
Message 12 of 25
(1,794 Views)
This is what I was hoping for. The text boxes are rarely needed in my program and take up a lot of space. Most of the time, I don't want to see any. That will be the next hurdle.
Message 13 of 25
(1,790 Views)
This works very well thank you.
Message 14 of 25
(1,786 Views)
Put them on a different tab, for example. Just hiding them is not that great, because you still need to keep their "lot of" space reserved for the occasions where they are visible. At least combine them into a cluster, so you can autoindex over their controls[] references based on the radiobutton value. HOw about using only a single textbox and change the contents depending on state?
Message 15 of 25
(1,785 Views)
No, this one doesn't work at all. It hides the radio buttons. That's not what I want at all.
Message 16 of 25
(1,790 Views)
Of course it "works", it just doesn't do what you want. 😉
There were no strings in the attachment of your original posts. If you want help with strings, attach a VI that contains all elements you need help with!
(Did you read my later messages?)
Message 17 of 25
(1,787 Views)
Accepted by RHutchings
Here's one possible idea. See if it can give you something to start....
(Note that the cluster order matters, of course, so make sure they match)
Message 18 of 25
(1,786 Views)
This is doing what I want. Thank you
Message 19 of 25
(1,755 Views)
 It is cleaner to keep the container visible, because the space is wasted anyway. Here's all you need to do:
Message 20 of 25
(1,750 Views)
