Script Error when click on Find Example in LabVIEW Help
Whenever I click on Find Example anywhere in the LabVIEW help, I get the following script error and the example does not open.
"An error has occurred in the script on this page.  The value of the property "openProj" is null or undefined, not a Function object"
It works fine on a different computer, so I located the example file and verified that it does exist on the problem computer.
The separate Example Finder tool (Help->Fine Examples...) works ok (opens examples) as well.
Message 1 of 69
(11,767 Views)
I get this error when I click on anything in the help file that requires a script, such as clicking the [+] button to add it to the block diagram.  Windows 10 LV 2012, LV 2015, LV 2016.  It just noticed it happening yesterday or something like that.
Bill
CLD
(Mid-Level minion.)
Message 2 of 69
(11,745 Views)
I've got the same problem here (running LabView 2014 Home on Windows 10)
Message 3 of 69
(11,726 Views)
Somehow I doesn't seem to get the script error if I open the labview help file "directly" from my file manager:
C:\Program Files (x86)\National Instruments\LabVIEW 2014\help\lvhelp.chm
So, there seem to be something wrong when accessing the same help file through Labview
Message 4 of 69
(11,720 Views)
I am running LabVIEW 2017. If I run Help directly, C:\Program Files (x86)\National Instruments\LabVIEW 2017\help\lvhelp.chm
Then click on a "Open Example" in the help I get "The webpage cannot be found" HTTP Error 404.
I also confirmed @Billko's observation that clicking the [+] Add or Find icon results in the same script error or webpage not found error.
Message 5 of 69
(11,711 Views)
What happens if you click the
Report a problem  link?
Oh, yes! That could help the help file.
Message 6 of 69
(11,702 Views)
I have not seen a "Report a problem" link. Do you mean the "Submit feedback link?"  I have used that in past.  This seems to go to an NI documentation group not to an NI support group.  The Submit Feedback link opens a page in your default web browser.
Message 7 of 69
(11,700 Views)
I am seeing the same problem here. (LabVIEW 2018.0f2, Windows 10).
Any button in the help:
  • Add to block diagram
  • Find on the palette
  • Open Example
  • Find related examples
Message 8 of 69
(11,687 Views)
Wow - I'm at home and I tried the same thing, got the same results - on LV 2014 (Home Edition) + Windows 7!
Bill
CLD
(Mid-Level minion.)
Message 9 of 69
(11,678 Views)
I actually noticed this a while ago, but wanted to investigate first. Thought it was something local since nobody else seems to mentioned it. 😮
  • It does not seem to matter what the default browser is (tried Chrome, Edge,  IE).
  • Running as administrator does not help.
  • Disabling AV does not help.
  • Yes, thing work if I open the chm file from within windows explorer.
  • It also works if I open help chm file using "control online help" (e.g. using <helpdir>\_LaunchHelp.vi)
  • Either LabVIEW calls the help incorrectly or there is a permission issue somewhere.
Message 10 of 69
(11,670 Views)
