06-17-2010 09:09 AM
Yep, that's what I was looking for. Thanks, I got a version that opens now.
Thanks Again,
Dave
06-17-2010 01:54 PM
MANY THANKS !
Luca
06-21-2010 10:54 AM
I am having difficulty opening this VI in LV2009.
From the date it was written (2001) I am going to take a guess that it is probably LV6 that it was written in.
I acquired this VI from this thread: http://forums.ni.com/t5/LabVIEW/counter-increment-and-decrement-in-a-while-loop/m-p/21392
Conversion to a Labview 2009 format would be greatly appreciated.
--Kevin
06-21-2010 11:01 AM
06-21-2010 11:02 AM
--Kevin
It's a LabVIEW 5 VI. Not all that much to it, although there's an extra unnecessary operation in the code. See if you can spot it. Hint: It's a Boolean operation. ![]()
06-21-2010 05:01 PM
Need help converting this 5.0 version library file to 8.6 version.
06-22-2010 09:21 AM
Attached is in 8.2. Seems to use Traditional DAQ.
06-22-2010 12:10 PM
Thank you! Ya this program was written long and now I have to try and revive it! good luck to me! Thanks again!
06-24-2010 03:52 PM
Could you please convert the attached files into version 8.0 for me (the files are zipped)? I am not sure what version these files were made from, but they were last modified in 1995.
Thanks a lot!
06-24-2010 04:19 PM
Hi hd83,
well, your files are made with LV3.1 - that's indeed old...
Anyone with a ready-to-use conversion kit?
In the meantime I would like you to look in the device drivers section of the website for something like this ![]()
