Upconvert VI Requests
@Eureka wrote:
I have a request, i would like to upconvert the driver for Wayne Kerr 3260B.
The current version is for Labview 5.1 and Labview 2011 says this version is too old to convert.
I posted the same request in :
http://forums.ni.com/t5/LabVIEW/Wayne-Kerr-3260B/m-p/1774566#M616045
RTSLVU did mass compile it in LV 8.21, but LV 2011 shows error saying some files are missing.
Nothing would be accomplished by having someone else compiling the same library. The issue is that you are missing files which come from another library. This is a library that has a "_u" near the end of its name. It was common in the old days to split a library into 2 files.
Message 1131 of 1,261
(1,402 Views)
smercurio_fc,
So, whats the solution? we dont have an updated version of this driver?
Message 1132 of 1,261
(1,396 Views)
Who is this 'we'? You are the one who downloaded the driver from someplace. Either you did not download the entire package, did not attach it, or it was missing from the download site.
Message 1133 of 1,261
(1,392 Views)
I downloaded the driver from the following link, its the one provided by the instrument manufacturer (Wayne Kerr):
http://www.waynekerrtest.com/global/html/products/woundcomponent/3260.htm
Message 1134 of 1,261
(1,386 Views)
You must have done something pretty silly. The WK3260B_u.llb is part of the download. You attach it if you want it converted.
Message 1135 of 1,261
(1,384 Views)
I have attached the file extracted from the downloaded zip file as im not able to attach zip files. There are other ".mnu" files. Do i need to attach those files as well?
Message 1136 of 1,261
(1,380 Views)
No, the .mnu files are just for the function palette. Since you already had the other library upconverted, I only bothered to do the "_u" one.
Message 1137 of 1,261
(1,372 Views)
Hi venkky, I'have the same problem of you.
I need to control my ITC 502 with Labview 8.2,
but the library given by OXFORD Instrument are
written in Labview 5.0.
The converted library you have now works fine?
Message 1138 of 1,261
(1,369 Views)
Can you please upconvert the "_dr" file??? Im still getting an error message when i try to open any of the VIs...
Message 1139 of 1,261
(1,365 Views)
That was already converted for you in the other thread! I'm certainly not going to do it again.
Message 1140 of 1,261
(1,363 Views)
