how can I make vi run faster?
@Emna20 wrote:
hi,
i want to know if there is  any other solution for this topic : https://forums.ni.com/t5/LabVIEW/how-can-I-make-vi-run-faster/m-p/3931129#M11171833
Typically one good solution is sufficient. How many different "solutions" do you actually need? Have you tried any of the suggestions? Did you encounter any problems?
Message 31 of 37
(1,081 Views)
hi ,i add a refresh button to the database code . i want to know your opinion to my code  .
Message 32 of 37
(1,058 Views)
If it works as expected, then it is good. Do you want a code review? Does the code do what you expect? Are you having any problems? Have you tried all that was suggested? Please share code and not pictures.
- A button named "button"? Really?
- Use the event structure to trigger on the "refresh button" instead.
Certified LabVIEW Architect
Message 33 of 37
(1,050 Views)
You cannot mix polling (the Boolean\case) with events!
Add a refresh value change event to the event structure. Put the refresh code in it. Put the result in a shift register.
Add an ID value change event to the event structure (remove it from the shared event with Button). Put the ID code in it, using the data from the shift register.
Rename Button to Stop.
When done correctly, the refresh will refresh, the ID will update the name\brand\reference and Stop will stop.
Message 34 of 37
(1,046 Views)
hi ,
@thols  you find below my code ( button mean : Home button )
@ wiebe@CARYA  what do you mean by put the result in shift register (while loop + Shift Register or for loop +Shift Register ) more explantation please  .
Message 35 of 37
(1,020 Views)
I already described what to do long ago.
Your above code is completely useless. Why would you need a case structure if both cases contain identical code???
Message 36 of 37
(998 Views)
Accepted by Emna20
Here's one (of many!) possibility. You really should start with a few more LabVIEW tutorials!
Message 37 of 37
(992 Views)
