how to do every 600 seconds to execute For loop?
HI,all
my for loop execute one has cost about 550 seconds
i want to  every 600 seconds to execute For loop
how can i do?
thanks~
Message 1 of 40
(4,068 Views)
Do you mean that you want to iterate the loop every 600 seconds or execute the whole loop every 600 seconds?  More details will help us give you a better answer.
You can use the time funtions (e.g. "Get Date/Time in Seconds")  to find out how much time has elapsed and allow the loop to iterate once you hit 600 seconds.
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
Message 2 of 40
(4,063 Views)
yes,
I mean that i want to iterate the loop every 600 seconds.
Message 3 of 40
(4,058 Views)
Like this?
Message 4 of 40
(4,053 Views)
You want to iterate every 10 minutes?  That's an extremely long time.  But here you go.
Message 5 of 40
(4,050 Views)
sorry,i express some error.
i want to wait 45 seconds then do this for loop at first
then every 600 seconds iterate this loop
how can i do?
Message 6 of 40
(4,040 Views)
Common guys please post in 2009 version please. I have attached a sample program if you use a time delay of 600 seconds then you have to abort the code to stop execution inbetween if you wantso better don't go for that.
Message 7 of 40
(4,038 Views)
OK, like this?  By the way, this is pretty basic stuff.
Message 8 of 40
(4,033 Views)
You really don't want to use a FOR loop for all that. The program needs to be interruptable at all times.
I suggest an event structure in a while loop. As an example, see also my links posted in my comment to a related idea.
Message 9 of 40
(4,027 Views)
Luis A. Mata C.
Ing. Electrónico
Whatsapp: +58-414-1985579
BBM Pin: 2B83E99A
Thanks: Kudos
Message 10 of 40
(4,007 Views)
