real time help and install
ok usb create is simply this: you download this program, it will use the usb and put files on it, you then stick it to your target PC, you load from USB and it will do a list of things, format etc and see if it is compatible with your computer
then after has succeeded then you will have to boot from c drive as it has reformatted to FAT32 system,
for me all goes well but when i load from the c drive after these steps, it then gives me the error message...i have done this many times and still errors
Message 31 of 43
(1,259 Views)
Sounds like you have a bad hard drive or a bad computer.  You would need to run a disk analyzer program on your hard drive.  It might show that the boot sector is corrupt, in which case you would have to replace the hard drive.  If you don't have a disk analyzer, it would be a fairly simple matter to just replace the hard drive and try the USB thingy again.
- tbob
Inventor of the WORM Global
Message 32 of 43
(1,252 Views)
I think it is possible your hard drive could be bad or there could be a problem with the software you are using.  If you intend to LabVIEW RT O/S on your desktop PC, follow the directions found in the following two documents.
Converting a Desktop PC to a LabVIEW Real-Time Target
http://zone.ni.com/devzone/cda/tut/p/id/2733#toc3
Using Desktop PCs as RT Targets with the Real-Time Module
http://digital.ni.com/manuals.nsf/websearch/55577282F097B537862575AD0058337F
Best,
Chris LS
Applications Engineer
Visit ni.com/gettingstarted for step-by-step help in setting up your system.
Message 33 of 43
(1,249 Views)
because before this it was working SMOOTHLY now it does not work, well if any case i will proceed with what you said than thanks?
Message 34 of 43
(1,248 Views)
Best,
Chris LS
that is what i did still nothing...
Message 35 of 43
(1,246 Views)
Your hard drive must have gone bad.  that happens now and then.  it is not uncommon.
- tbob
Message 36 of 43
(1,243 Views)
even if windows is reformatted on the computer and it works still does this thing?
Message 37 of 43
(1,234 Views)
What do you mean "even if windows is reformatted".  You don't reformat windows, you reformat the hard drive.  You can reformat the hard drive until the chickens come to roost, but if you hard drive is bad, it will never boot.  Replace your hard drive.
- tbob
Message 38 of 43
(1,227 Views)
thanks i will see if that will make a difference
Message 39 of 43
(1,219 Views)
Hi Chris,
I am a beginer.  I have a Dell Optiplex 760 with Intel(R) Core(TM)2 Duo CPU E8400@3.00GHz with 1.93GB 2.99GHz RAM.  The network adapter is Intel(R) 82567LM-3 Gigabit Network Connection.
I have NI Developer Suite 2011.  I use LabVIEW2011.
Other things I have:
LV Real-Time Deployment Option
FPGA Deployment Option
LabVIEW Real-Time Deployment License for Standard PC's- ETS RTOS
NI PCIe-7841R Virtex-5 LX30
I would like to setup this PC to a real-time target.  And another Dell Optiplex 760 as a development computer.  Is this doable?
I cannot get a definate answer from NI UK support team quickly.  Could you help?
Thank you in advance.
Kind regards,
Qing
Message 40 of 43
(1,005 Views)
