07-06-2010 04:45 PM
I am using version 5.1. Could you plese send me the new mailer.cbx also.
Thank-you
07-08-2010 01:12 AM
tell me your email address
07-08-2010 10:23 AM
My email address is jerryl@westernprecooling.com
07-29-2010 08:11 PM
Can you please send the file to me too.
I am using lookout 5.1.
Regards Randy
05-25-2011 12:21 PM
Ryan,
We are using Lookout Version 6.0.1 and are having mailer problems. We need to switch to port 465 with SSL. Can you please send the file with instructions to steve.g@commplus.org
Just to add, the problem we are experiencing is when a mailer is sent, it can take seconds to an hour for the user to recieve them. AT&T recomends we change to 465/SSL.
05-25-2011 08:57 PM
I have sent you the updated mailer object for 6.0.1. You can change the port by setting the ini file.
But the problem is our mailer object doesn't support SSL.
05-26-2011 01:11 PM
Hi Ryan,
Is there a solution for the SSL?
05-26-2011 08:30 PM
You cannot use lookout mailer object to connect the mail server which requires the SSL, like gmail.
05-27-2011 07:25 AM
Ryan,
I understand that. Do you know of any work around to get the email to a server that requires SSL?
05-29-2011 08:18 PM
I don't know a workaround if you use Lookout mailer object to connect server using SSL.
Maybe it's an option to use 3rd party mailer utility.
