06-28-2011 01:25 PM
Ryan,
thank you for the mailer.cbx and mailer file for the port change, however it does not seem to work. I took the file and put it in the lookout directory. I also changed the original mailer.cbx to mailerold. When I boot into lookout I get an error "the original 3116 could not be located in the dynamic link library lkworks.dll" click ok and will not open an existing file with a mail setup. It comes up with "could not load class?" click ok and then gives us an "error running process file". If you setup a new process and try to add a mailer object (object, create, monitoring)the mailer choice is not there.
What are we doing wrong.
Lookout version 6.0.1
Steve
07-18-2011 05:31 PM
Hello Ryan,
I have a customer using version 4.5 on an older system that was emailing just fine until port 25 was blocked. Do you have an update that would work for us?
Pete
07-18-2011 05:33 PM
sorry email address is peter.brini@ (**no spam**) bauerct.com
12-17-2012
09:49 AM
- last edited on
07-09-2021
02:08 PM
by
NI_Community_Su
Hi Ryan,
Having the same issue, using lookout v5.1, need to use port 587.
cheers
12-17-2012 11:38 AM
Tools that may help you:
Port Mapper: Maps a local port to a remote port. For example you could set local port 25 to your servers 587 port.
http://www.analogx.com/contents/download/Network/pmapper/Freeware.htm
Proxy: Set a local or network proxy that can access other servers and ports
http://www.analogx.com/contents/download/Network/proxy/Freeware.htm
Good luck
