Lookout
Mailer Object - Specify Port
I am using version 5.1. Could you plese send me the new mailer.cbx also.
Thank-you
Message 21 of 35
(4,269 Views)
tell me your email address
Ryan Shi
Message 22 of 35
(4,260 Views)
My email address is jerryl@westernprecooling.com
Message 23 of 35
(4,255 Views)
Can you please send the file to me too.
I am using lookout 5.1.
prnpage@yahoo.com
Regards Randy
Message 24 of 35
(4,181 Views)
Ryan,
        We are using Lookout Version 6.0.1 and are having mailer problems. We need to switch to port 465 with SSL. Can you please send the file with instructions to steve.g@commplus.org
        Just to add, the problem we are experiencing is when a mailer is sent, it can take seconds to an hour for the user to recieve them. AT&T recomends we change to 465/SSL.
Message 25 of 35
(3,882 Views)
I have sent you the updated mailer object for 6.0.1. You can change the port by setting the ini file.
But the problem is our mailer object doesn't support SSL.
Ryan Shi
Message 26 of 35
(3,870 Views)
Hi Ryan,
Is there a solution for the SSL?
Message 27 of 35
(3,864 Views)
You cannot use lookout mailer object to connect the mail server which requires the SSL, like gmail.
Ryan Shi
Message 28 of 35
(3,858 Views)
Ryan,
      I understand that. Do you know of any work around to get the email to a server that requires SSL?
Message 29 of 35
(3,856 Views)
I don't know a workaround if you use Lookout mailer object to connect server using SSL.
Maybe it's an option to use 3rd party mailer utility.
Ryan Shi
Message 30 of 35
(3,841 Views)
