Machine Vision
NI-IMAQ for USB and usb Cameras
Hi all
I just tested logitech qc 400 pro under vision asisstan 7.1.1 and it works perfectly.
ni imaq for usb must be installed after vision assistant,
"Qod natura non dat, Salmantica non praestat"
Message 11 of 56
(4,520 Views)
Hi all
ni imaq for usb must be installed after vision assistant, so the usb camera is displayed in cameras window.
My configuration is  XP Pro
Message 12 of 56
(4,523 Views)
Sorry about this post
labview 7.1
ni vision and vision assistant 7.1.1
driver for logitech is qc846
hope it helps
Alipio
Message 13 of 56
(4,524 Views)
Hi again.
After searching some other threads I came to the conclusion that it could be a OS language problem.
In my case with Win XP pro sp2 dutch installed, the driver doesn't work. After installing Win XP pro sp2 english it works fine!!
grz
Message 14 of 56
(4,520 Views)
Hi
i work with
Logitech QuickCam® Pro 4000
and LabView 7.1.1 and Vision Module 7.1
its perfect.
I install the "Logitech QuickCam® Pro 4000" Driver and nothing more.
It's perfect.
Mor
Message 15 of 56
(4,497 Views)
I have read in the forum that can be a problem with the licenses,i explain my case
I have licensed, with green light:
Vision
Vision
Fernando Mora Torrijo
Spanish studient
Message 16 of 56
(4,497 Views)
Could be a problem with the licenses:
I have licensed:
Vision
Vision asistant
Labview
But i have yellow light in remote panel conection.
Please help me i m a spanish studient, and is necessary for my final degree project.
I have tried with a quik cam express plus and with a Genius VideoCAM NB and in both cases in Vision asistant i see this mesage: The setings for this camera are invalid or something like that, and i cant change the camera settings.
Spanish studient
Message 17 of 56
(4,497 Views)
Hola Fernando
Tu caso parece extraño, pues todo deberia funcionar sin problemas.
La conficuracion que yo tengo es
Windows xp pro SP1 español
Labview 7.1
Ni vision and assistant 7.1.1
NI IMAQ for USB
WEBCAMS logitech pro 4000 y qc communicate
Driver de logitech qc846esp
El unico punto a tener en cuenta es que hay que instalar o reinstalar IMAQ for USB despues de tener registrado todo lo de Vision y labview.
Si sigues teniendo problemas, te recomiendo probar con QTlib ( para usar webcams basado en quicktime). Puedes descargralo de su web gratis, el toolkit de peter parente basado en el activex de logitech.
Si sigues teniendo problemas, trata de reinstalar todo. Debe funcionarte bien
Saludos
Alipio
Message 18 of 56
(4,492 Views)
Hi all,
yes ! i forget to tell that
NI IMAQ for USB
is MUST !
I have :
LabView 7.1
Vision assistant
Vision Module 7.1
NI-IMAQ last version
running OS : Windows XP SP2
i install the Logitech Camera Driver, and than the "NI IMAQ for USB"
and open the Vi's examples from the "NI IMAQ for USB"
and everything work perfect.
Sorry if i can help any more...
Mor
Message 19 of 56
(4,489 Views)
I think it might be the problem that Vet Hard mentioned.  There are some programs that only work on one OS language.  I think that the LabVIEW <-> USB interface may need Windows to be English to work correctly.  Could you try it on a computer with an English Windows installation?  If you have one available, that would at least give us mroe data.
Hope that this helps,
Bob Young
Message 20 of 56
(4,476 Views)
