10-19-2005 08:37 AM
thank you all, the OS could be, but i downloaded windows xp prof sp1+2 from the emule and i installed it, the results were the same: The parameters dor this camera are invalid, in vision assistant, now i can recibe images with robloab thanks to allpio, i m developing a studient vision system, all your help is needed if you want, you are great people.
I m learning english too jeje with the forum.
I m waiting for my labview studient edition, i buyed it.
But i want to solve my usb camera problems with vision assistant, isn´t a cmmon thing, it may run perfectly
Fernando Mora
10-20-2005 03:40 PM
11-07-2005 07:18 PM
11-09-2005 02:09 PM - edited 11-09-2005 02:09 PM
Mensaje editado por Tania Lozoya
01-04-2006 11:02 AM
There is now a way to add support for non English OSes...please see the thread here:
http://forums.ni.com/ni/board/message?board.id=170&message.id=154541&view=by_threading&page=2
06-04-2008 01:34 PM
Hi!
I have a problem in my application installer. I have built a VI which acquires images from USB camera and transmits them through DataSocket. The application runs well, on both Source and Receiver computers (video transfers well on the network).
My problem is that when I built the Installer for this application, it didn't include (and didn't allow to include) NI-IMAQ USB (Vision Assistant) and so when I install this application on another computers, it doesn't execute because the .vi for USB Capture is missing. It shows message as "NI-IMAQ USB init.vi" not found. I don't have this .vi on my computer.
When I included USB Capture instrument on my program, it automatically created a .vi, so it doesn't exist physically.
Any solutions?
Thanks ahead!
06-05-2008 08:56 AM
Hi vaibhav,
We have a knowledgebase on our website that explains how to do exactly what you want. I suggest you take a look at this link.
Requirements for Computer Running an EXE Using NI-IMAQ for USB Functions06-05-2008 02:03 PM
Hi!
Thanks a lot for your attention!
I have visited this page and other pages also, on this topic. I have followed all the steps. Still I face the error.
Any clues?
Thanks ahead.
06-06-2008 10:20 AM
Hi Adam!
I have visited several forums and help pages, and also knowledge bases from NI, but my problem continues. I feel I am doing somewhere very small mistake which is not explained in any of these pages.
I have attached a screen shot of my program with this message. The program works OK on the development machine. Then I build a project, create an Application (EXE), add this .vi as a source file and two .dll's, mentioned on these pages
How do I Deploy LabVIEW 8.x.x Applications with NI Vision 8.x.x?
LabVIEW 8.2 Application Builder Readme
I then, build an Installer, including the above created EXE (with a data folder) to Programfiles and the .dlls in SystemFolder. In Additional installer, I include NI Run-time Engine 8.2 and Vision Run-time Engine 8.2.1 and still after installing my application on another computer, I get the message of "IMAQ USB init.vi" Not found or "IMAQ USB Close.vi" Not found.
Do I need to make a source distribution? However I did that also, and included it in the installer, which means I included the above mentioned missing vi's in my application installer. And still it didn't help.
Do I miss some very obvious step here? This problem is taking longer than I expected and I haven't seen others facing similar error message. So I guess I am missing some obvious step.
Thanks ahead!
06-06-2008 10:53 AM
Hi vaibhav,
Did you do everything in the knowledge base I pointed you
to? Including placing the dll’s onto the
source computer and registering the ImaqDirectShowExport dll? Since the code works fine on the development
machine I think the problem is on the source computer not with the code its
self. It might be worth a shot to try
building a installer that runs a very simple VI that dose NOT include the IMAQ
for USB functions. This will make sure everything else if functioning correctly
outside of the IMAQ for USB. I must also
point out the National Instruments dose not officially support IMAQ for USB so
there may be some issues with it.
