01-02-2007 04:21 PM
Eric,
Thanks for your help. I have contacted Dalsa, and they have sent me a set of Labview VIs that will work with the Spyder Gige camera. However, they were written in Labview 8.0, and I have Labview 7.1. If I email them to you, can you convert them to 7.1?
Gretchen Zimmer
01-02-2007 05:42 PM
01-03-2007 09:50 AM
Oh, yes, I have tried IMAX over & over. first, I had the Dalsa driver installed, now I have the NI driver for the Intel PRO/1000 installed. I still cannot see the camera. I asked dalsa about the firmware, but here's a copy of their reply:
Hi Gretchen,
I have attached some sample code which will help you use the camera in Labview. The camera will not be automatically recognized by their software.
Andy Buck
Product Support Specialist
DALSA
I tried opening the sample code, but it was written with LV 8.0. I emailed back, to see if Dalsa could convert it for me, but here was their reply:
Hi Gretchen,
Unfortunately I do not have access to Labview and will not be able to do this. Perhaps you could contact NI?
Andy Buck
DALSA
I have installed Vision Acq 8.2.1, and tried to look at the examples, but again, they are written in LV 8.x. Can't look at them.
Gretchen gzimmer@pppl.gov
01-03-2007 09:50 AM
Hi Gretchen,
Andy Buck
DALSA
Hi Gretchen,
Andy Buck
DALSA
01-03-2007 10:13 AM
Oops, a correction! I can open the example IMAQdx VIs - it's the LV examples that came with the Dalsa QuickCam software that I cannot open. I just opened & ran Snap, but it says 'Camera Not Found'. (not a big surprise, since I can't see the camera in IMAX)
I have downloaded & installed a trial version of V Acq 8.2.1. Purchased version is on the way. Perhaps I'll have better luck with that version???
Gretchen
01-03-2007 10:30 AM
01-03-2007 10:43 AM
The sticker on the back says 'SG-10-01K80-11E', and was purchased recently (Fall '06). I appreciate your help & feedback. I will send another email to Andy at Dalsa.
Gretchen
01-09-2007 11:08 AM
Email conversation with Dalsa follows:
Subject: Camera Vision compliant?
To Dalsa: The sticker on the back of my Spyder says 'SG-10-01K80-11E'. The number immediately underneath that is: 16000101 (The Revision #?)
Is my camera 'GigE Vision compliant'?
Regards, Gretchen Zimmer
Hi Gretchen,
No, your camera is not GigE Vision compliant.
Is there anyway I can make it compliant? Possibly a firmware upgrade?
Gretchen
Unfortunately not.
so that's that. ....... Gretchen
03-27-2007 12:50 AM
03-27-2007 01:03 PM
Status as of March '07 [I've been struggling through various solutions ever since my original post]:
I CAN NOW SEE THE SPYDER GigE Camera via IMAX!!!
Dalsa had to send me a firmware upgrade, which I applied, and voila! I could see the camera! [Must use NI driver.]
I can do basic acquisition of images with Labview. However, Dalsa states that I have to use their New GUI interface called Coyote to set the camera parameters, and I'm finding Coyote not sufficient for our application.
Gretchen Zimmer
