Machine Vision
basler 相机 aca 1600 连接问题,那位大侠能给出点主意
Message 1 of 11
(4,614 Views)
Your question must be: Why do I get this error?
Just check this:
Is your ethernet card Gigabyte?
Does your ethernet card support Jumboframes?
Did you enable Jumboframes?
Did you turn off your firewall?
Regards
Message 2 of 11
(4,613 Views)
There is a solution to the Test Packet Time Out Error located at http://digital.ni.com/public.nsf/allkb/8D9A975B04F66B728625768900805A21.
Robert Eastlund
Graftek Imaging, Inc.
Phone: (512) 416-1099 x101
Email: eastlund@graftek.com
Message 3 of 11
(4,609 Views)
my ethernet card is Marvell Yukon 88E8057 PCI-E Gigabit Ethernet.how can i know my ethernet card support Jumboframes. my ethernet card setting like this
Message 4 of 11
(4,599 Views)
Message 5 of 11
(4,594 Views)
Select the Test Packet Enabled attribute and set it to be disabled the soft show a error
my soft seeting like this
Message 6 of 11
(4,592 Views)
In you NIC property panel, set the jumboframes to the highest value (ie about 9000bytes).
Regards
Message 7 of 11
(4,584 Views)
大哥,你的这个相机搞定了吗?我现在手上也有一个,我是个初学者,可以指点一二吗?恭候
Message 8 of 11
(4,311 Views)
Hi Robert, this only applied to a very small number of the Scout series with a very specific firmware. The Ace and any other cameras do not have any bugs with the Test Packet functionality that require it to be disabled.
Eric
Message 9 of 11
(4,309 Views)
问题已经解决。最后使用labview2011连接相机就没有再出现问题。
Message 10 of 11
(4,302 Views)
