03-08-2012 02:32 AM
03-08-2012 05:11 AM
Your question must be: Why do I get this error?
Just check this:
Is your ethernet card Gigabyte?
Does your ethernet card support Jumboframes?
Did you enable Jumboframes?
Did you turn off your firewall?
Regards
03-08-2012 04:30 PM
There is a solution to the Test Packet Time Out Error located at http://digital.ni.com/public.nsf/allkb/8D9A975B04F66B728625768900805A21.
03-08-2012 08:51 PM
03-08-2012 09:18 PM
setting like this
03-08-2012 09:44 PM
I Select the Test Packet Enabled attribute and set it to be disabled the soft show a error
my soft seeting like this
03-09-2012 08:24 AM
In you NIC property panel, set the jumboframes to the highest value (ie about 9000bytes).
Regards
03-12-2013 12:58 PM
大哥,你的这个相机搞定了吗?我现在手上也有一个,我是个初学者,可以指点一二吗?恭候
03-12-2013 01:16 PM
Hi Robert, this only applied to a very small number of the Scout series with a very specific firmware. The Ace and any other cameras do not have any bugs with the Test Packet functionality that require it to be disabled.
Eric
03-13-2013 06:36 AM
问题已经解决。最后使用labview2011连接相机就没有再出现问题。
