incorrect analog input resolution
My PCI 6052 has an analog input resolution of only abou 1mV instead of around 300uV. I was wondering what could cause this.
(3,496 Views)
Greetings,
What range and gain settings are you using? If you increase your gain, do you see your code width decrease?
Let me know.
Spencer S.
(3,496 Views)
No matter what gain setting I use the resolution is still around 1 mV. It does not seem to change.
(3,496 Views)
Strange. . .What software are you using to program your application? How are you adjusting the gain?
(3,496 Views)
