Home
Community
Discussion Forums
Most Active Hardware Boards
Multifunction DAQ
Topic
Multifunction DAQ
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
incorrect analog input resolution
riverside
Member
01-24-2003
06:16 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
My PCI 6052 has an analog input resolution of only abou 1mV instead of around 300uV. I was wondering what could cause this.
0
Kudos
Message
1
of 4
(3,535 Views)
Reply
Re: incorrect analog input resolution
Spencer S.
Active Participant
01-27-2003
02:14 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Greetings,
What range and gain settings are you using? If you increase your gain, do you see your code width decrease?
Let me know.
Spencer S.
0
Kudos
Message
2
of 4
(3,535 Views)
Reply
riverside
Member
Author
01-27-2003
02:41 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
No matter what gain setting I use the resolution is still around 1 mV. It does not seem to change.
0
Kudos
Message
3
of 4
(3,535 Views)
Reply
Spencer S.
Active Participant
01-31-2003
08:06 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Strange. . .What software are you using to program your application? How are you adjusting the gain?
0
Kudos
Message
4
of 4
(3,535 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
