Multisim and Ultiboard
Ultiboard 5.61 crash
My Ultiboard (Ver 5.61) crashes after I open it with the following error message:
    An Error Occured!
    Exception nr: 0xC0000005, STATUS_ACCESS_VIOLATION
    Address: 0x442735
What can I do to get it up and running?
Thanks for help
SXHugo
Message 1 of 11
(6,153 Views)
you are 5 versions behind.....download version 10.  Your not going to get any kind of support for a completely dead and completely obsolete version.  I'm betting it is written for win98 and not NT kernels.......even though it shouldn't matter unless the drivers are different.  If it worked before and not now......you must ask.....what changed.  Other than that, I suspect your on your own.
Signature: Looking for a footprint, component, model? Might be here > http://ni.kittmaster.com
Message 2 of 11
(6,146 Views)
Hello SXHugo,
yes, you are 5 versions behind. Like me. I am still working with 5.72, because since V6 (UB2001) everything is completly different but unfortunately not better. Smiley Sad Smiley Mad
I can not help you with my limited english, but you should explain a little bit more what you are doing before the error occurs.
Greetings,
Lutz
I am working with :
UltiCap 2001 & UltiBoard 5.72 (for my daily work on XPpro-SP3, german)
Multisim Power Pro 10 (small & simple simulations)
Ultiboard Full 10 (no)
start looking for professional alternatives...
Sorry about my english!
Message 3 of 11
(6,133 Views)
Unfortunaely, I am not going to be of any assistance with Version 5.61. Although I did at one time have this version it was many years ago, and it has since been removed from my previous computers and I don't even know where the discs went.
What I can suggest is maybe posting your file if that is posssible. It sounds like LODIN may be able to load it and see what is occurring if he is willing to try. Using UB10 to try and figure out what is happening would be of no use to you and Version 10 is all I have.
I hope someone can give you some help with this, but it is a very antique version of UB. It may work just as good or if not better than 10, but the support is more or less gone for it.
I wish you good luck in finding what is happening.
Kittmaster's Component Database
Have a Nice Day
Message 4 of 11
(6,124 Views)
I used V5.61 since about 10 years without any problem. Why shoul I by an new version with a lot on new functionality and a very high price?
I was happy with v5.61
I installed it on an other system and it run's - but ony once. The second time I  started it - it also crashed. Then I restored the system (Win XP) to a time in the past - and I could start it again - one time!
When I start it, the main window opens and it asks 'Please select a product class'. After pressing 'OK' it crashes.
SXHugo
Message 5 of 11
(6,099 Views)
Hello SXHugo,
I know what you mean with the newer versions Smiley Mad
I had often the feeling, that Ultimate 5.xx has problems with not correct paths. But I don't know anything exactly. Did you try to start an existing PCB by a double click ? If Ultimate starts, check the paths in "options/files&paths".
Sorry, but that my only ideas at this moment.
Lutz
I am working with :
Message 6 of 11
(6,093 Views)
Hello SXHugo,
did you find the problem ?
greetings,
Lutz
I am working with :
Message 7 of 11
(6,039 Views)
Hello Lodin,
No, I still looking for a solution or an alternative. Maybe I switch to Eagle.
Are you from Germany? (I am).
SXHugo
Message 8 of 11
(6,006 Views)
Hello SXHugo,
yes, I am German. I will contact you by PM.
Greetings,
Lutz
I am working with :
Message 9 of 11
(5,968 Views)
I can not find any message system on this forum Smiley Sad
.. and the time to edit is much to short !Smiley Mad
Hallo SXHugo, Du kannst mich hier erreichen : Lodin_Erikson@yahoo.de
Greetings,
Lutz
I am working with :
Message 10 of 11
(5,963 Views)
