NI Package Manager (NIPM)
Broken NI Feed?
I have user that was experience an installation issue I have not seen before. The process had just worked for them the other week, but I wonder with the latest LabVIEW 2019 patch had changed the situation. As part of the installation, NIPM's command line is used to install several packages, which currently included a dependency to LabVIEW 2019 runtime engine. The specified version is listed as available, however then the installation runs, nipkg.exe states it cannot download there package file. Is there something wrong with the NI feed for the follow package?
Command Line Error
Downloading ni-labview-2019-runtime-engine_19.1.2.49153-0+f1_windows_x64.nipkg: Done
Error -125011: The feed URL you are trying to reach is not available. Check to make sure the URL is correct, and that the server is running and configured to accept remote requests (https://download.ni.com/support/nipkg/pool/ni-l/ni-labview-2019-runtime-engine/19.1.2/19.1.2.49153-0...).
I was able to temporarily work around by manually installing the package from the .nipkg file I had previously downloaded on another PC. However, if this is going to continue to happen, I would have to rewrite our installation routine.
__________________________________
Bill Eisenhower
Certified LabVIEW & TestStand Developer
Message 1 of 10
(4,304 Views)
Can you please explain the exact steps you followed to get this error?
Message 2 of 10
(4,244 Views)
The user ran our installation batch script that called nipkg.exe command line to install packages from our internal feed. One of the packages has a dependency on the runtime. As it was installing it got the error. The runtime package version is listed during nipkg.exe list, but it could not install since it could not be downloaded.
Bill Eisenhower
Message 3 of 10
(4,228 Views)
I'm getting the same error, with a reference to ni-labview-2019-runtime-engine-x86...
I've tried several times with no success.
Message 4 of 10
(4,210 Views)
Unchecking the update for 32-bit Labview 2019 allowed the update to work, but since that's what I use, I'm not sure where I stand now.
Message 5 of 10
(4,207 Views)
Because of caching issue, the f3 and f4 patches were not listed intermittently. Can you please check now?
Can you also share the feed list? "%ProgramFiles%\National Instruments\NI Package Manager\nipkg.exe" feed-list
Message 6 of 10
(4,195 Views)
The Runtime is still not available again this morning. I have attached the list of NIPM Feeds.
Bill Eisenhower
Message 7 of 10
(4,181 Views)
I have filed a service request, #01166587, on this issue.
Bill Eisenhower
Message 8 of 10
(4,143 Views)
Accepted by CL_eisenwr
Bill, I do not have access to the service request that you highlighted, however, my understanding is that the underlying issue has been fixed for the LabVIEW 2019 SP1 f4 Runtime (64-bit) installer. You may want to try your use case again.
Scott Richardson
https://testeract.com
Message 9 of 10
(4,050 Views)
Scott,
I just got email this morning from support letting me know as well. My issue does appear to be fixed now as I could now install that failed earlier.
Bill Eisenhower
Message 10 of 10
(4,030 Views)
