Community Browser
Top Authors
Post an idea
I sometimes delete controls from the BD and realise some time (from milliseconds to minutes) that I have some broken local variables.
I get greeted by the hugely informative imagery as shown below:
Yeah, good luck realising what exactly you deleted by mistake.  No name, no way of finding out what the local PREVIOUSLY linked to.
I suggest retaining at least the name of the Control / Indicator the local was linked to so that the poor programmer (me) has some fighting change of undoing the error.  Bear in mind there could be many changes made to a VI before this kind of thing is notices so a simply "undo" fix could end up being VERY awkward indeed.
An example of how this could look:
Here I at least know WHAT I have deleted by mistake.
When programming with large applications, often times you'll have clusters carrying a lot of information.  If you hover over the cluster wire and observe Context Help, you might see something like this:
This Context Help window above is rather large and doesn't necessarily make it any easier to see the structure or contents of the cluster. My proposed idea calls for the ability to expand or collapse the cluster contents within the Context Help window, such as this:
What do you think?
I would like to be able to change the z-order of FP Objects programmatically. For starters, I envision the following properties:
  1. Layer - Explicitly sets the z-order layer in which an object resides.
  2. Promote/Demote - Implicitly sets z-order layer by -1 or +1 (assuming Layer 0 is frontmost)
  3. Send to Back/Send to Front - Explicitly sets z-order to the foremost or rearmost layer
  4. (Optional) Container property "Layers" - Returns an array of all layer indices currently in use by the container (Page, Panel, Cluster, etc.)
  5. (Optional) Container method "Layer.Objects" - Returns array of references to all objects on a layer
Question at this point: can more than one object reside on a layer, or should each object represent a discrete z-order? Does changing the z-order of one object likewise affect the z-order of other objects? Discuss in the comments.
Often, when modifying code, I need to reduce the size of a structure due to removing code.  If I have a nested structure system (e.g. event structure in a case statement in a loop), this can get very tedious.  It would be nice to have a "shrinkwrap structure" functionality on the right-click menu as a counterpoint to the autogrow.  This would be an action that would reduce the structure size to something a bit bigger than the largest contents.  An option to set how much extra space to include would be nice.
I'm developing code, and like most people I know, I have multiple VI's open at once.
If I then go and open the VI properties dialog, I lose track of what VI the properties are for, especially if I get an interruption.  I know I can just close the properties window and open it again for whichever VI I wanted (or go to the parent category to see the name), but this could be solved by simply adding the name of the VI to the window title of the Properties dialog.
like this:
I would like to have an option to export a simplified image of a graph directly into png. The image formats available in LV2010 are bmp, eps, emf and pict. Png is superior to bmp with rougly 100-50 times smaller file sizes. At the moment if I want to export a simplified image of a graph to png then I have to use the extra code below or alternatively export the image to clipboard, paste that into a graphics editor an save it to png. It would be much more simple to have an option to directly export to png. My suggestions below:
I'm not sure if this idea already exists, at times i wish to have an option to display the line numbers in a string control/indicator/constant.
Line numbers
NI's response to the ideas thus far appears far too sporadic. For example if you check out the top LabVIEW ideas (http://forums.ni.com/t5/ideas/v2/ideaexchangepage/blog-id/labviewideas/tab/most-kudoed) 7 of the top 10 ideas are still listed as new! Adding insult to injury the average age of these ideas to date is 1,017 days! It is ok to decline ideas but please provide us some indication that this is something you take seriously. It would appear that NI is cherry picking the easiest half dozen or so items from the list so you have a marketing gimmick to list on the LabVIEW release notes. I propose that a threshold is set and made public so that if an idea reaches a certain amount of kudos, R&D must address it, even if that means declining it.
Add functionality/property to allow a cluster to have a scroll bar.  This way, long clusters with many elements can be shrunk down to a manageable front panel size and a scroll bar would navigate through the cluster elements.
Sometimes you want your front panel fixed to a particular size. Sometimes you also want to access the “Tools,” “Window,” or “Help” menus.
When you have intentionally re-sized your front panel to a specific (small) size, it’s a pain to have to resize the window or switch to a different window every time you want to access something under “Tools” or any of the other menus that are not visible.
(Sure, I could switch to the block diagram and get to the menus from there. But if I can’t remember the keyboard shortcut to open the block diagram, I have to resize the window to get to the “Window” menu to open the block diagram.)
For example, when you make an XControl, you want to re-size the facade to fit the controls that you put on it. And then you want to keep it at that size. On the built-in Simple Dual-Mode Thermometer example, you can’t see any of the menus past “Edit” on the Facade without re-sizing the XControl.
It would be nice if an arrow or something appeared on the menu bar when the window is sized too small that I could then click on and expand to get to the menus that are not visible.
The Find Items With No Callers dialog box in Project could use a Remove From Project feature. Currenly, we have to use Go To, then remove the VI, then generate a new  Find Items With No Callers list.
This is written as both an Idea and as a Community Nugget.
Did you know there exists a function that decreases code fragility when it comes to typecasting and type converting datatypes? It's called 'Coerce to Type', and I bet you've never heard of this function unless you have kept up with this conversation. Thanks to RandyP for creating that Idea which culminated in a 'public' release of the Coerce to Type function.
21195iD087EF25489F6CED
Since that post, I have become aware of potential risks/bugs I had been proliferating in my coding style. First, I will briefly describe my understanding of the difference between typecasting and typeconverting in the context of LabVIEW. Next, I'll show a few use cases where this node increases code robustness. Finally, it's up to you to Kudos this Idea so we get Coerce to Type officially supported and in the palette!
Simply, "type converting" preserves the value of a wire, and "typecasting" preserves the raw bits that express that value on a wire. These two concepts are not interchangeable - they perform distinctly different data transfer functions (which is why they show up on two separate subpalettes: "Numeric>>Conversion" and "Numeric>>Data Manipulation"). Then there's this new function: Coerce to Type. I think of it as a Coerce-Cast combo. The data input is first Coerced to the datatype harvested from the top input, and then it is typecasted to that type.
Dynamic event registration is sensitive to the name on the wire, and for documentation's sake it has historically been important to typecast the event source ref to achieve a good name. Well, typecasting refs can get you into trouble (ask Ben), especially if you change the source control type while forgetting to update your "pretty name" ref constant.
21187iA83D4F02211D2DCB
My next favorite example is when you need to coerce a numeric datatype into an enum. Sometimes it's impossible to control the source datatype of an integer, while it's desirable to typecast the value into an enum for self-documented syntax inside your app.
For instance, take the "standard" integer datatype in LabVIEW - I32 - and cast it to an enum. You're going to get some unexpected results (assuming, you expected the *value* to be preserved). Consider the following scenario:
  1. You desire to typecast a plain integer '2' into an enum {Zero, One, Two, Three}, and after 45 minutes of debugging, realize "Typecasting" has hacked off 75% of the bits and clobbered the value. Drats!
  2. The enterprising engineer you are, you determine how to fix the problem with a deftly-placed "Coerce to U8". (This is one of the fragile errors I proliferated prior to learning about this node)
  3. Maniacal manager/customer comes along and says "I want that enum to count to 10k". Drats again. A datatype change from U8 to U16 for the typedef'd enum, and a lot of typing with the wretched enum editor. Finally, two hours into testing and wondering why the program doesn't work, you realize you also forgot to replace all of the Type Converts to U16 (this is the definition of fragile code: you change one thing, and another thing(s) breaks).
  4. Rockstar Programmer Epiphany: use Coerce to Type, bask in your robust code. You even enjoy data value preservation from floating point numbers.
21191iD3339D40A531F181
Finally, typecasting can generate mysterious failure modes at Run-Time, but Coerce to Type can catch errors at Design Time. This is especially helpful for references (see above), but can also prevent some boneheaded data gymnastics (see below). Whew! Saved by compiler type resolution mismatch!
21193iC698E122C5BE16AC
In short, now that you realize you need this function, I hope you will want to see it added to the Data Manip palette.
Penultimate note: Coerce to Type is neither a replacement for typecast nor any of the type converts!!! There are distinct scenarios appropriate for each of the three concepts.
Ultimate note: please check the comments section, because I expect you'll find corrections to my terminology/concepts from GregR, et al.
Have you ever created a cluster like this?
I have. Numerous times. It's fairly easy to create clusters which get out of hand. The magic number is usually around 10-15 elements, assuming some of them are clusters as well, but even if those numbers are manageable, I've also created larger ones, and those aren't manageable.
Using LVOOP mitigates this to some degree, but does not solve it completely.
So, it would be great if we could divide the cluster into "pages" or "categories":
This will allow us to logically divide the cluster into manageable areas.
The names of the pages will appear in the selection list and in the unbundle node, as shown in the example (although you could hide them in the node by unchecking the full names option), but they will NOT actually be part of the element's name. Changing the name of a page or moving an element from page to page will NOT require you to change code which already uses that element.
Notes -
  1. In my mockup I used a tab control. I understand that LV R&D has some aversion to the concept of tabs inside clusters, so I would like to make it clear that I'm NOT asking for a tab inside a cluster. This is purely a cosmetic and organizational feature.
  2. I already posted this as a comment on this idea, but I figured it was worth posting as a separate one.
I sometimes feel difficult to see the value of a wire while editing the VI. When "Retain Wire Values" is turned ON, I need to put a probe on that wire to see last executed value. Applying probe on every other wire while coding will result in lot of probes and also it will increase the coding time.
Having a way to view the wire value on Mouse Hover in edit time will be really useful. What I feel is, the value can be displayed as a tooltip or a dialog box similar to context help window which will disappear when mouse pointer is removed from the wire. 🙂
LabVIEW classes are how you create new data types in LabVIEW. But part of being a new LV data type is having a front panel representation. Although users can write XControls for displaying their classes, and they can put those XControls in the palettes, whenever a user of their class chooses "Create Control" or "Create Indicator" for the LabVIEW class terminal, they get the cube display. In order to really add a new data type to LabVIEW that behaves as well as, for example, the Timestampp or the Waveform, there needs to be some way to associate a class with an XControl and say, "This particular XControl should be used as this class' default control/indicator whenever one needs to be built."  (To prevent infinite recursion and load dependency problems, whenever you did Create Control/Indicator on a member VI of the class, users would still get the cube control/indicator.)
Currently, the space constant looks very similar to an underline character, possibly causing confusion.
I think the icon could be made a bit more distinctive. Here are some alternatives I just made up. I would probably prefer (1) but I am open to any other suggestions. 😄
The current method I use for centering a subVI called from a caller ("parent") VI is rather involved:
Instead, a new property should be introduced to the Run-Time Position under VI properties:
The shortcoming of not being able to have a subVI popup center on the parent is something that has bugged me in the past, and I was inspired by lvABC's idea to create this broader idea that would apply to all subVI's.
Say you have new errors you want to merge into an existing structure. You have to expand the merge error, then bring the new error to the merge. Here is what I'm proposing.
Start wiring the new error, then click on the merge error node.
LabVIEW expands and connects the error wire
This would also be nice for any expandable node like build array, concatenate strings
Bonus points idea, but might cause more polarization so don't let the entire idea hinge on this. Clicking on an existing unbroken wire can insert the node.
The existing UI behavior just wires a new source into an existing wire, which really only breaks the wire. I'm not sure the above behavior would take capabilities away from the user. For build array to work this way, it would have to detect if the singleton was the same type as the array wire you were clicking on. This is a bit more iffy in my mind.
I really like the new arrow feature with block diagram comments.  But in many cases, I have a comment that applies to more than one BD object.  So, I would like the ability to link my comment to multiple objects instead of just one.
This would allow me to turn this:
into this:
Thanks!
-John
For as long as I can remember (I have used LabView since 4.0) the decorations and contropls pallette have remained unchanges for the most part.  End users want an application more like the iPhone than windows98.  We need a new decorations capability to be able to customize controls  to a high level.  The square circle and triangle of 2 colors and flat or 3d/rounded nolonger cuts it.  I would like to see a new type of decoration.
- Decoration made of vector graphics so it is scalable, user can add or remove verticies and move them around to make new shapes.
- Labview native color pallet linked to item colors (default can be 2 color option of FG, BG but scale this to an array of colors to make more complex decorations)
- Colors add transparancy and alpha channel
- Grouping allows building of a single new decoration from several  primitive shapes.
- Decoration possible support gradients (color blending)
*** Decorations should have optional labels so that they can be addressed programatically
-Decorations added to customized controls that have lables associated with them become part of the control and can be accessed via a property (ie can be set to not visible through a property node)
I know this is asking quite alot, but I have found that when I make my applications not look like LabView (and it is easy to spot a LabView application) it is not a well recieved as when I present a highly customized application that does not look like a labview example.  Allowing the community to easily create very professional looking new controls and indicators will do wonders for our GUIs.
