Community Browser
Top Authors
Post an idea
I suggest NI include a native feature to serialize LabVIEW objects in an interchangeable form.  (Alternatively, NI can at least provide enough access to allow a third party to develop such a framework.)
By "interchangeable" I mean in a manner that allows sharing object data between platforms (e.g., between LabVIEW and Java).  (Hence having "default data" without specifying the values of the default data is not allowed.)  Moreover, using a more common format (such as "Simple XML") is appropriate.
Of course, including the object version number is only meaningful within LabVIEW, but this is useful within LabVIEW thanks to the capability of LabVIEW objects to translate between versions.  (Note: I recognize the versioning can't avoid all possible issues, but in practice I think that is rarely a practical issue.)
I understand that for security reasons a developer may want to turn off the ability to serialize an object.  To support that, I envision a checkbox to allow serialization (default = True) in the class properties dialog.
I think XML is the best option for this for several reasons:
1) It is a common way to serialize objects in different environments.  This means that I can exchange serialized data with Java applications, for example.
2) It is readable, albeit not easily readable, by human beings.  (I actually don't want humans to read serialized data very often--and really never the operator, but it is good that they can on the rare occasion when they need to do so.)
Why I think NI should implement this:
1) This is relatively straightforward for NI to do since NI can already serialize a class to the current (noninterchangeable) LabVIEW XML format.
2) Having this capability could greatly expand the application space of LabVIEW, since it would make it orders of magnitude easier to interface with nonLabVIEW applications.  This is especially important in large systems, in which it may be advantageous to implement some system components in one environment and other components in another environment.  This is, I think, by far the most compelling reason to include this feature.
3) That there is a need for this seems obvious, given the number of lengthy discussions just on LAVA about this topic.
4) The current situation, in which each class must contain specific code for serialization, is patently inefficient and nonsensical.
5) In other major languages meaningful object serialization is a given, and LabVIEW should include (indeed, must include) this functionality to be competitive.
For the record, to serialize LabVIEW object data for communication within LabVIEW we use either the methods to flatten to string or to XML, and this works fine.  I realize it's not theoretically 100% fool-proof, because of potential issues across different object versions, but in practice we use version control, so that we build applications using the same versions of interface code (usually), and we only have one large system, so we can pretty easily control our deployed applications.   (I think that versioning an application could achieve the same.)  In practice, we've never experienced a version problem with this approach, and it avoids having to write any class-specific code (which, again, a developer should definitely not have to do) to support serialization.
Add cmd line parameter to LVCompare.exe which would contain the file name for an image file.  If the image file name exists in the cmd line parameter, create an image file that contains all of the differences between the two vi's.  The images would be the same via LVCompare.exe, when stepping through the differences and doing an equivalent print screen.  It would be nice to automate the process of documenting the differences between two vi'.
Message Edited by Laura F. on 12-17-2009 08:38 AM
Idea:
Create a free, stripped down edition of LabVIEW for general purpose programming (GPP). Let's call this hypothetical edition "LabVIEW Lite". By GPP, I mean programming tasks that have nothing to do with data acquisition, test, or measurement- tasks such as creating generic PC, mobile, and web applications. Former text-based programmers would flock en mass to LabVIEW Lite for GPP use cases if a free, stripped down IDE were available. Imagine the recent popularity of the Eclipse IDE and Java, only with LabVIEW Lite and G!
Rationale:
  • LabVIEW Lite would exponentially promote the paradigm of graphical system design.
  • Few (if any) structural dataflow languages are available for GPP.
  • Structured dataflow languages are insanely cool! Inherent parallelism, increased productivity, and hierarchical system design are only a couple of reasons. These are things other GPP programming languages can't offer.
  • 16, 32, 64, ... core consumer devices are coming! LabVIEW is poised to exploit parallelism in a way that is hopelessly messy with text-based languages.
  • GPP use cases of LabVIEW Lite would spark user ideas for many non-GPP use cases, for which NI would receive full LabVIEW and NI hardware sales.
Implementation:
  • No measurement/test/data acquisition VIs or tools.
  • No FPGA tools.
  • Application (exe, dll) builder for stripped down applications.
  • The LabVIEW IDE we all know and love.
  • Primitive types, clusters, structures, loops, file i/o, etc. provided.
I think it's a shame that programmers today aren't using G! What do you think?
I hope LabVIEW wishes to become the next-generation all-purpose programming language that will be used all over the world in all industries.
.NET and Java are the dominant Technologies in almost the entire world.  With the introduction of the ability to create a .NET Interop Assembly with LabVIEW 2009, I was very excited because I thought that now I could go back to several former employers and make a convincing argument for them to use LabVIEW.... But then I realized,  yes, I can now expose my code written in LabVIEW to .NET applications, but my code cannot do many things which are standard in those worlds.  For example:
I can create a .NET Assembly, but I cannot:
  • inherit .NET classes
  • use generic .NET classes
  • create.NET classes that use generics
  • implement .NET interfaces
  • expose a LabVIEW event to a .NET caller
  • expose a LabVIEW class to a .NET caller
  • cannot create Office Plugins, or any other Plugin that requires me to implement an interface
i.e. almost every single financial institution has an in-house developer that creates various Excel Plug-Ins and Add-Ins, LabVIEW cannot be used to create such a product because LabVIEW cannot inherit from and implement the IDispatcher interface.
The CLI - Common Language Infrastructure is an open specification developed by Microsoft tha
It allows anybody to create a programming language that creates fully compliant .NET code.  There are 3rd parties that have created products such as ActivePerl and ActivePython, which allow developers to use Perl and Python (and even COBOL!) to create .NET compliant code.  My vision is for LabVIEW to do the same, so that now every single organization in the world that uses any .NET language can also consider using LabVIEW, without having to run into many issues along the way.  Only with full .NET compliance will random worldwide organizations consider writing a portion of there software in LabVIEW before hopefully moving entire projects onto LabVIEW!
Message Edited by John80 on 09-03-2009 01:49 PM
As described in the following "Darren's Weekly Nugget" posting, LabVIEW provides an API for programatically building projects. Especially when dealing with large projects, this can be a real time saver and great technique for quality control (ensuring that the build process is carried out the same way each time). However, when doing a programatic build, there is no status information - the LabVIEW application that calls these APIs is just left, giving the impression that it has locked up. This can be especially concerning given that builds of complex applications can take quite a while.
A solution seems pretty straight forward - give the build API calls, the option to display the standard building dialog.
A simple boolean value could allow an API user to provide some feedback to the hosted application as to what is going on without any of the complexities of other status feedback mechanisms (although *any* mechanism would be better than none!)
Weekly Nugget Posting regarding App Builder API: http://forums.ni.com/t5/LabVIEW/Darren-s-Weekly-Nugget-02-15-2010/m-p/1072575
Like it or loathe it, Microsoft Excel is heavily used for storing, recording and analysing lots of data and many LabVIEW programmers must find they need to get data into or out of Excel. However LabVIEW lacks the ability to read and write Excel files directly. It is possible to exchange data with Excel via ActiveX automation, but this:
  • requires Excel to be installed on the same computer as the LabVIEW application
  • is not cross platform
  • is complicated to do
  • does not appear to work reliably across different versions of Excel
The Report Generation Toolkit allows creation of Excel files but this costs extra and is not cross platform.
Many software packages can read data directly from Excel .xls files (e.g. Umetrics SIMCA-P) and presumably it is therefore also straightforward to write data out in Excel .xls format. Native LabVIEW functions for reading and writing .xls files - for example, into string arrays - would be very useful. It would not be necessary to support formatting, charts etc - although some kind of basic formatting support might be useful.
Of course it is possible to exchange data with Excel via delimited files (comma- or tab-separated values) but the .csv format requires characters such as quote marks, commas and carriage returns in a string to be escaped so that they are not incorrectly interpreted as part of the file structure. Tab-separated files suffer less from this problem but on Windows at least, files with a .tsv extension are not automatically associated with Excel whereas .csv files are. It would be helpful if LabVIEW also had native functions for reading and writing .csv files with correct escaping for Excel.
When you get a data changed event from an array, it would be nice if that event included an array of what items in the array actually changed.  This makes it easier for the user to determine what changed and how to deal with it.
With LINQ (Language-Integrated Query) becoming increasing prevolant in .Net programming, more and more classes are using <T> Generics.
Unfortunately, LabVIEW does not support Generics, which limits the Methods and Classes available when importing .Net Dll's.
Take the following code:
namespace GenericsTest
   public class GenericList<T>
      void Add(T input) { }
   public class NonGenericList
      void AddNoT() { }
   class TestGenericList
      private class ExampleClass { }
      static void Main()
         // Declare a list of type int.
         GenericList<int> list1 = new GenericList<int>();
         // Declare a list of type string.
         GenericList<string> list2 = new GenericList<string>();
         // Declare a list of type ExampleClass.
         GenericList<ExampleClass> list3 = new GenericList<ExampleClass>();
When importing this to LabVIEW
Notice that I can only see the "NonGenericList" Class as LabVIEW fails to destruct the "GenericList" Class.
One solution to this problem may to treat generics as Method/Constructor inputs, allowing the developed to choose the Generic Type.
You can right-click on a While Loop and select "Replace with For Loop", and vice-versa:
Neither of these operations is currently available in VI Scripting. If they were, Quick Drop and other G-based editor features could benefit.
The LabVIEW Task Manager is an outstanding tool for debugging LabVIEW Applications. It should be included in LabVIEW in my opinion.
Now that scripting is "legal" we need to be able to do more with it, when it comes to the event structure scripting is weak.
Here are a couple of discussions where people wish for more scripting functions around the event structure :
Triggering an event on a picture created with LV Scripting
- Remove Frame Not Implemented
How do I get the cases in an event structure
- Event Structure Selector Labels
We need to be able to add and edit event!
When building reusable components I create a set of classes that work together to accomplish some larger goal and put them all in a lvlib.  Sometimes some of those classes are optional--they are not required by the library for it to work but they can make it easier for users to use the library for certain tasks.  These optional classes belong in the same namespace as the library.  One behavior of libraries is that they load all inner libraries.  When the inner library is a class all the class member vis are loaded, which wastes time and consumes resources when the classes aren't needed.
My current options are:
- Don't include the classes in the library.  Consequence:  I run a higher risk of name collisions and there's no continuity.
- Put each optional class in its own independent library.  Consequence:  Namespace pollution and a reliance on an arbitrary convention to figure out what libraries should be used together.
- Put the optional classes in the library.  Consequence:  Resources are used needlessly.
Usually I do the last option as it provides a more cohesive user experience.  I wish I didn't have to.  An lvlib is a functional grouping of code.  A namespace is a logical grouping of code.
To be explicit, I would like to be able to define namespaces for each library such that:
- I can have a single namespace that crosses multiple lvlibs.
- I can have multiple namespaces within an lvlib.
- I can add libraries to a namespace without rebuilding all the libraries in the namespace.
- Loading a component with a specific namespace doesn't automatically load all sub-namespaces.
Futher,
- I'm not requesting the ability to separate a single class into multiple namespaces, nor do I think that's a good idea.
- I don't mind the class name being part of the fully qualified namespace.
I would like to expose the "Replace With..." method in the LabVIEW Project Right Click Popup menu via VI Server/Scripting.
This would allow e.g. a developer to update the LabVIEW Project after a SCC Rename transaction and preserve all linking.
Currently this is unavailable.
17225iD565D229419523A1
In fact I would like a lot more exposed, see here, but Antoine and I agree this was more important and may have more chance of happening quicker?
Now that .NET 4 is out and people are using it to program, LabVIEW should support the .NET 4 framework. LabVIEW needs to stay on top of the game and make it easy to use all the latest technology. Especially something as widely adopted as .NET.
Currently, no version of LabVIEW (released or in Beta) supports .NET 4.
I would be helpful if the Python nodes supported Python Virtual Environments. One of the powerful features of Python is able to setup multiple separate environments on a single computer, it would be LabVIEW's Python integration could also leverage this. TestStand already does have this capability, so hopefully it could be quickly/easily leveraged into LabVIEW. 😁
I am happy that LabVIEW supports Python code with the Python Nodes. But it is difficult to debug errors. A console showing the output of the Python Scripts would be handy.
Enthought's Python Integration Toolkit had this function so I guess it shouldn't be a big thing to add?
Currently the lvsound2 library -- the Sound Input and Sound Output VIs supported by lvsound2.llb and lvsound2.dll -- updates the audio device list from the operating system only when first being loaded into memory. If you change the device list (e.g.., pair/unpair a Bluetooth headset) the device IDs will not reflect the new configuration until all the lvsound2-dependent VIs have been unloaded from memory. After adding or removing a device, the VIs will generate error 4803 ("The sound driver or card does not support the desired operation.") for device IDs related to the new/removed device,  even if the ID is still actually valid and points to something else. This is extraordinarily inconvenient for test systems focused on audio device testing, but understandably a niche issue, which may be why it hasn't been caught before now.
In the interim, the workaround is to dynamically call any of the VIs you're interested in to force them to load/unload as necessary. There are two appropriate solutions I can think of:
1) Update the Sound X VIs to implement the dynamic call workaround (preferably directly around lvsound2.dll calls so we can still borrow other VIs in the LLB).
2) Update the DLL to support on-the-fly changes.
The latter solution is ideal, particularly for performance. This reads both as a suggestion and a bug report so that anyone else who has this problem can find a public forum documenting the issue.
A .NET assembly can mark some of its items as deprecated to alert users of those items to not use them for future applications. This is part of the .NET standard. It looks like this:
[Obsolete("This is the message you get!")]
In other development environments the developer will see this message when using a deprecated item.
This is an example of what it looks like in the Visual Studio editor. The item is underlined and when you hover over, the message is shown:
This is an example from Visual Studio builds:
However LabVIEW does not. If you're developing a LabVIEW application using .NET interfaces... You might use deprecated functionality by accident. To avoid this... LabVIEW users like myself generally have to have intimate knowledge of the assembly or the documentation up on another screen just to make sure they are not using deprecated items.
I propose we mark items in a special color to indicate they are deprecated. I chose pink here for no reason. Any color is fine:
Also, we should indicate the item is deprecated in the class browser in some manner. Again, I just drew some stuff, doesn't have to be exactly this:
I would like the VI icon to be the icon which shows up in the file browser instead of the default LabVIEW VI or control icon.  There should probably be a switch to turn this on and off, since I can see the utility of having a specific icon for VIs, controls, etc., but in normal use, the VI icon would work much better.
When you want to find out where exactly a control is located on a computer screen (for some dark reason), there is a method for Panes called 'Convert Pane coordinates to Panel coordinates'.
However there is no easy way to get the owning pane of a control!
The propery 'Owner' of a control always returns the actual VI, not the pane.
Ton
