Community Browser
Top Authors
Showing results forย
Search instead forย
Did you mean:ย
Post an idea
Firefox is not publishing the PNG data that contains a snippet inside the Drag and Drop info, however the info is stored inside CFSTR_FILEDESCRIPTOR (source) it would be very helpfull if LabVIEW supported this as well.
TOn
At the moment you can Register for Events using a Cluster of Refnums.
But you cannot Destroy User Events or Unregister for Events in this way.
This approach allows for you to scale your application without the need to change the code that handles Registering Events.
It would be very convenient to be able to close references in this way (using a Cluster of Refnums) too, as per my illustration below:
21670iEFD0527198796259
Title says it all really.
Openoffice is cross-platform and free.  All good points.
Please?
Shane.
The detailed help link in the LabVIEW Context Help window is a great way to add extra documentation to your LabVIEW code.  However it currently only supports .hlp, .chm, .htm, and .html files types.  This should support many more documentation types such as pdf, txt, doc, .xls, png, .etc, etc.
I often need to interpret JSON formated Strings.
Until now I use regular expressions.
A JSON-Parser (like the LabVIEW-XML-Parser) should simplify the expense for me drastically.
I've long wished Labview had native support for Interfaces.  Recently I ran across an article describing Traits as a better alternative to Interfaces, Mixins, Multiple Inheritance, etc.  Traits are (as near as I can tell) similar to Interfaces with the main difference being Traits can define a method implementation while Interfaces can only define a signature.
I'd like to see Traits implemented in G instead of Interfaces.
(Cross posted to LAVA.)
When youโ€™re making a By Reference LabVIEW Object using a Data Value References (DVRs) the user of your class would need to embed each Dynamic Dispatching VI inside an In Place Element Structure (IPE). Or you have to create wrapper VI for each method but this undermines the advantages of LVOOP Inheritance.
The idea is that a DVR containing a LabVIEW Object wired to a Dynamic Dispatching Terminal is equal to calling the Method VI inside the IPE structure like illustrated below.
Message Edited by Support on 01-15-2010 04:39 PM
Current methods for the LabVIEW Project that exist as Right Click Popup Menus are not exposed via VI Server/Scripting.
However, these methods would be very handy to call programmatically.
I say, if we can Right Click Popup on it, then we should be able to script it!
[Cross-posted here on the JKI blog]
One LabVIEW feature that (if it existed) would make a big difference for VIPM users is the ability to refresh the menus (e.g., the FileTools, and Help menus) programmatically after installing packages that add menu-launch VIs.  Maybe we could do this if LabVIEW added a new VI server method called Application:Refresh Menus.
Note: this would be similar to how we can refresh the palette menus programmatically by invoking theApplication:Refresh Palettes method (shown below).
refresh-palettes
I bring this up, because one feature that Iโ€™d love to see added to VIPM (some day) is an easier way to build menu-launch tools into VI Packages, and Iโ€™m sure more people would be asking us why their add-on doesnโ€™t show up in LabVIEW after itโ€™s installed.
Hopefully, we can help NI get this feature onto the LabVIEW roadmap by convincing them that itโ€™s worthwhile.
Currently it's only possible to have drag and drop events for files on a path control.
It would be usefull if we could have drag and drop events for files on any control.
This way simpler GUI can be build with a very nice user experience.
Ton
As part of a review of a shipping product, I want to make sure that all of our LabVIEW-built executables are using the same version of LabVIEW so that we also only have to ship one version of the LabVIEW Run-Time Engine. Everyone I've talked to has given me advice on things to change at export time, build time, or even run-time to know the version of LabVIEW it was built in (e.g. the App.Version property), but what if I want to know the version of an EXE I have already built?
Here are the methods I've tried so far:
1. I created a set of VIs that does it crudely by reading the EXE file in as if it were a text file, finding mention of lvrt.dll, and then scanning back a few hundred bytes to try and find a version X.Y token in there. (Of course this could be done in any language, not just LV). This solution can be automated for my product release's review process, but it would be prone to failure if the EXE format changes or my assumptions aren't correct. I wrapped the solution in one that searches our installation directories for all EXEs and returns all LV EXEs with versions (as they are detected here) and all non-LV EXEs so I can verify that my tool is not giving false negatives on LabVIEW-based executables.
Parse EXE as text for Version
(See attached .zip file for my LV implementation)
2. Run the EXE on a machine with no LV RTE and read the version from the error popup that you get when it launches. Obviously this requires user interaction, and requires launching the executable.
3. Install all LV RTE versions you think the EXE most likely requires. If it launches without incident and stays in memory, you can use Process Explorer to figure out what libraries it has loaded and see which version of LV RTE was called (since the lvrt.dll will be under "<NISHARREDDIR>\LabVIEW Run-Time\<Version>"). Obviously this isn't easily automated either, and requires launching the executable.
4. I tried using Dependency Walker to see what lvrt.dll dependency was found, but it didn't show me anything useful. I'm guessing it's dynamically loaded somehow, and DepWalker can't tell me?
What I'd really like are two things:
1. An LV Invoke Method like "Get VI Version" and "Get VI Editor Version" that works on built applications -- "Get App Version" with the same types of inputs and outputs as (file path input, string version output and U32 version output). An added output to determine platform and/or bitness would be nice, too.
2. An LV RTE property that tells me the Run-Time version in the file's properties. I could potentially automate checking of this via .NET calls or something like that
It is common, in writing reusable code, to handle arbitrary clusters in variants.  To access the elements of the cluster, one wants to convert the cluster into an array of variants containing the individual items.  After access, one needs to convert the array of variants back into the original cluster.
There are several examples of packages that use this on NI.com and in the LAVAg.org Code Repository.  They mostly use functions for working with Variant Clusters from OpenG; however, these can be quite slow.   Recent LabVIEW versions have had the ability to do much of the functions quicker, however, there is a very imortant missing native ability: to convert an Array of Variants into a Variant Cluster.
The other direction, Cluster to Array of Variants, works like this:
But trying to reverse the process breaks:
So my idea is make the second image work; make an Array of Variants interchangable with a Variant Cluster in the "Variant to Data" LabVIEW primative. The interchangability should apply to contained subclusters/arrays also.  The matching of array to cluster elements can be by cluster order rather than element name.
This would greatly aid the performance of reuasable packages that operate on arbitrary clusters.
There have been several ideas proposed to alleviate accidentally savings vis in the wrong version of LabVIEW. While useful, I think the main problem is that LabVIEW doesn't use the information it reads from the file to preserve compatibility. I'd like to propose here that LabVIEW introduce compatibility modes for previous releases in which LabVIEW will break a VI if a feature is introduced that isn't supported by the compatibility version. It will essentially be a built-in, seamless "save for previous" mode.
By default, LabVIEW will load a VI (hierarchy) in a compatibility mode for whichever version is was saved in. If the user tries to make a change that isn't compatible, LabVIEW will alert the user and the user can tell LabVIEW whether it's ok to save to a newer version that supports the feature.
The level of alerts can be configurable, of course.
Related ideas:
Version-aware LabVIEW launcher
Add header to LabVIEW file to contain the version of LabVIEW
Display VI version in title bar
Version independent Source Code Saves
With the increasing size of the LabVIEW ecosystem, there is a growing number of third party tools written in LabVIEW that are versioned independently from LabVIEW's version number.  For example, I could create an API that has versions 1.0, 2.0, and 3.0, and all three versions could be compatible with LabVIEW 2009 or later.  Tools like VI Package Manager make it easy for content creators to publish multiple versions of an API, and for users to upgrade and downgrade between those versions.  However, this ease of use disappears if significant changes have been made to the VIs in an API, such as:
  • Changing VI connector panes
  • Renaming or moving VIs on disk
  • Adding VIs to a library
If any of the above changes are made to VIs in an API between versions, it can become impossible to migrate code between the two versions without a lot of manual searching, replacing, and relinking.
LabVIEW should provide a mechanism to define mappings between old and new versions of third party toolkit VIs.  Consider the case where I make the following changes to a VI from my toolkit:
Version 1.0
Version 2.0
VI Path
<userlib>\mytoolkit\CompRes.vi
<vilib>\mytoolkit\Compute Result.vi
Owning Library
none
Mytoolkit.lvlib
Connector Pane
I should be able to create a mapping file included with version 2.0 of the toolkit that describes the changes made between versions 1.0 and 2.0 of the VI.  This way someone could write an application that calls version 1.0 of the VI, then upgrade their toolkit to version 2.0, and the application source code would be able to find, load, and relink version 2.0 of the VI without any hassle.
When manually analysing a project, we can set the target in which the VIs should be loaded. Unfortunately, VIs with RT code are often broken under windows, leading to wrong test results, or even worse, pop-ups asking for VIs.
Please add an Application Reference Input for the VIAn Run.v.
Maybe this option could also be useful set in the VI Analyzer configuration file?
With the advent of scripting, it is possible to create some nifty tools to aid in code writing.  Those that work on individual elements of the FP or BD can often work nicely in Quick Drop or the Right-Click Framework.  Some of these tools however, work most naturally as an addition to to Tools menu.  The missing piece of the puzzle for seamless integration into the IDE is the ability to customize keyboard shortcuts for those additions.  I would simply like the ability to assign keyboard shortcuts to any item which appears in the Tools menu.  I have at least three things in there already more worthy of Ctrl-t.
Although I expect that it will take a while before this is implemented I would like to add the request so NI can start thinking about it.
As you might have noticed that Microsoft announced a few things on Microsoft build 2015.
Aside from the hololens and windows 10 for the raspberry pi they both share 1 common factor. They both run "Universal apps" (see http://www.engadget.com/2015/01/21/windows-10-makes-microsofts-dream-of-universal-apps-come-true ).
So it would be great if we can run LabVIEW programs as a "universal app" and run our code on all windows 10 devices..
It would be awesome if there was an option in project window to set if the method is contained within a .lvclass file or ouside of the .lvclass next to it in the folder.
Now it's like this:
It's hard to use a class like that in a plugin architecture with VIs on the outside. Lets put everything together inside like a LabVIEW LLB!
How it should be:
Don't get me started on Packed Project Libraries ๐Ÿ˜‰ We just need LLB functionality, for the class to behave like a folder and we are happy ๐Ÿ™‚
Piotr
Invoke nodes can have lots of optional arguments, resulting in their taking up a lot of vertical space.  I would like to recommend that the arguments portion of Invoke nodes be resizeable, allowing the developer to select the optional arguments to be displayed on the block diagram and, hence, have more control over the layout of the block diagram.
Consider the Save-As Invoke node from Microsoft Word:
Current Microsoft Word Save-As Invoke Node
which gets longer with each new version of Word.
Now imagine being able to show just the optional arguments that are needed:
Just the Optional Arguments that are Needed
And, as an added bonus, this Invoke node would not break when the VI is opened in a development environment that has a different version of Word with the same exposed optional arguments.
One practice which is increasingly debated in the community is the packaging of code for distribution and collaboration, and which tools to use.
I suggest that NI should define and maintain an open standard for distributing packages of LabVIEW artefacts (.vi,  .lvclass etc).
And include a frontend to this in LabVIEW. This package manager should handle dependencies between packages and across LabVIEW versions and targets. The typical use cases would be:
  • The distribution (online or shipped with labview) of:
    • NI examples
    • NI drivers
    • NI toolkits
  • The distribution of third party species of the above
There should also be an API so that applications can use this mechanism to be modular and extensible.
Cheers,
/MArcus
