Community Browser
Top Authors
Post an idea
Incorporate NI Batch Installer Builder into the general application builder suite.
This tool has a lot of potential for end-user use if it is incorporated into the app builder API and suite.  Batch installers can be used for much more than just installing selected sets of NI software (Which this tool is obviously designed specifically to do).  It could be used for creating installers of multiple, cross-project user installers comprising a complete system.  To do this though, the current batch installer builder needs to be made more generic to be of use.
Specifically:
  • Add configuration options to control or disable license dialogs when non-NI provided installers are added
  • Add configuration options to control or disable the user/company license dialogs when non-NI provided installers are added
  • Add configuration options to control or disable the check for NI updates dialogs when non-NI provided installers are added
  • Add batch installer version properties to allow end users to create system versions
  • Add support for 3rd party installer inclusion (Dup from another idea, but I had to repeat it here)
Including this in the app builder would be even better since that should allow project based configuration and control of the batch configurations and potentially even programmatic control.
It would be nice to improve documentation created by Tools->Import->Web Service... wizard.
Especially, I suggest to automatically create Description in created .lvlib Documentation so that it would be immediately clear which WSDL URL is handled by that library. Currently, WSDL URL is only placed as a String constant in Open Web Service.vi which is not really convenient.
Thanks for understanding and support.
It would be nice to get the Test Case Comment into the report. Also, please add programmatic access to read it out.
I have been recently asked by NI to answer a poll about what feature I would like to see as far as data management and access and at that time, I didn't really think about mentioning something which is dearly missing in LabVIEW: cloud storage access.
The reason for this request is that increasingly, files used by collaborations cannot always be copied locally (for instance due to their size or because of frequent updates), or managing local copies and updating the central cloud repository is getting prohibitively time consuming and cumbersome.
There exist a few attempts in this direction (e.g. GDrive for LabVIEW, a third party skeleton of a toolkit to access Google Drive, or LabVIEW Interface for Amazon S3), but there are some glaring absent ones such as Dropbox, OneDrive, Box or iCloud to name the most popular ones.
As I mentioned before, GDrive is a starting point but is missing some basic features such as folder list, comments, etc.
I cannot comment on Amazon S3, as I don't use it.
Obviously, there is no way to predict which cloud storage solution will disappear in a few years from now or which one will pop-up tomorrow and become popular, but most of the work has been done by those vendors, who provide .NET API for their cloud solutions (maybe not Apple) or at the very least a RESTful API. These APIs could of course be made community projects (like GDrive is to some extent), but their importance would seem to justify a minimal investment from NI.
As we increasingly integrate with HTTP servers the LabVIEW functions appear more and more limited.
Authentication is a major concern and in enterprise environments one option is NTLM (or Windows Authentication).
I would like to see the HTTP client support this as in this case we had to abandon using LabVIEW for the integration.
Formula node is a great tool for evaluating mathematical formulas and expressions. However right now, you can one time input text into the formula node (during application development) and after compilation, the node does only this one added text and any change would mean a recompilation of the code. It would be absolutely fantastic to dynamically load the node text for example from some file…the node would then have not only a variable input, but also one text input, and the text would bet the formula node text.
It would then be a upgraded sort of a „eval formula node.vi“, which would accept also syntax for while loops, for loops and all the other stuff and not only a regular expression.
I'm surprised a search did not turn up anything about this.  NI should create a LabVIEW Amazon Web Services/Azure/Docker Image(s).  The sample case I am thinking of is having a Jenkins CI server running on AWS EC2 with a full LabVIEW environment installed.  This would allow off-loading the long FPGA or full RF suite builds during CI.
Apparently NI had this with LabVIEW 2012 on AWS
I would suggest to NI the following steps:
  1. Collect underpants
  2. create AWS LabVIEW image for cloud-based compiling - charge per use
  3. Use AWS to work out the kinks to get an efficient, speedy image created
  4. Open an NI data-center that does what AWS/Azure does but for the tech/engineering field and host all of their own software images
  5. Profit (or at least start to pay back that huge CapEx outlay)
Thanks!
Charlie
The goal of this idea is to make it easy for the LabVIEW ecosystem to create reusable libraries for LabVIEW that would be type independent. Let's think for a second dictionaries, also called as key-value stores. Dictionaries are data structures that allow storing and retrieving values with a specific key. To create a generic reusable strongly typed dictionary is currently impossible with the LabVIEW type system. One can create a dictionary that is type specific but then it's not reusable. Or one can create a reusable dictionary but then it's not strongly typed. Type Parameters and Parametrized Generic Types as explained in this idea would allow creating strongly typed dictionaries that are widely reusable across applications. Specifically type parameters and parametrized generic types would allow LabVIEW ecosystem to develop highly reusable strongly typed components to solve various common programming problems. This would allow National Instruments to put more focus on the core of the language as the LabVIEW ecosystem could solve much wider range of problems that preivously have required National Instruments to contribute.
Add a new control type Type Parameter to LabVIEW that augments the current Control, Type Def and Strict Type Def control types. The Type Parameter type would act like a regular Type Def control with one special and important distinction. You could wire anything to an input terminal expecting a specific Type Parameter type and the downstream type would adapt at compile time to the type wired to the type parameter input.
Type Parameter Definition
In a single VI type parameter could be used in multiple places but all instances of the type parameter would adapt to the same type.
Type Parameters
When a VI that uses Type Parameters in the front panel is used on a block diagram, the template VI is replaced by the compiler by a type specific instance that has adapted the type parameters to the type wired to the Type Parameter input. Notice below how in our VI the control and the indicator were of type Type Parameter with a default type of DBL and the instance got adapted to type U32 that was wired to the input.
Calling a VI with Type Parameter Inputs
The same type parameter could be used on multiple inputs of a VI.
Multiple Inputs of The Same Type Parameter
And all of the type parameters would adapt to the same type when the VI is being used.
Calling a VI with Multiple Type Parameter Inputs of the Same Type
Note that in the above example we chose the element of the array to be a specific type specified by a type parameter. However the arrays themselves could as well have been specified by a type parameter.
So far we have focused on VI boundary where type parameters adapt the whole VI to specific type or types if multiple different type parameters are being used in the connector pane of the VI. Type parameters can also be used in composite types (e.g. arrays, clusters, classes) and the downstream composite types would adapt to what is wired to the type parameter input.
Type Parameters with a Cluster
Note that x and y as instances of the same type parameter have to be of the same or compatible type.
Type Error With Type Parameters
Type parameters can also be used in class private data to create parameterized custom types. This is where type parameters become extremely powerful. Let's assume that we have a class 3D Vector.lvclass that has three instances of a "Data Element.ctl" Type Parameters. The default type of the Data Element is set to be DBL. The cluster private data has three instances of the Data Element, one for each of X, Y and Z.
Type Parameters in Class Private DAta
Now we could create a Create 3D Vector method VI for this class that allows us to construct type parametrized instance of the class type.
Creating a Type Parametrized Object
Now calling this Create 3D Vector.vi with string as the inputs for type parametrized inputs X, Y and Z will create an instance of class 3D Vector with compile time type 3D Vector[String].
Calling a VI that Creates a Type Parametrized Object
And this is where we now start seeing the superpowers of type parameters and parametrized types as well as generic type parameterized VIs that go along with them. Now we have a capability of creating custom VIs and custom types that both can adapt to different parameter types at usage time.
Let's get back to the question of dictionaries. We could easily construct a dictionary that allows the key type to be parametrized with one parameter and the value type to be parametrized with another parameter. For example we could use the dictionary with I32s as keys and Strings as values. Or we could use it with Strings as keys and File Paths as values. Constructor for such custom type would be trivial to create.
Type Parametrized Create Method for a Dictionary
Once we have constructed the dictionary we would naturally like to use it. We could now use method VIs of the Dictionary class to add and fetch elements from the dictionary. As an example Get Element By Key would look something like this in it's simplest form.
Get Element From Dictionary
Note that Dictionary In is type parametrized with two different type parameters Key Type and Value Type. In the class library there is a Type Parameter control Key Type.ctl and Value Type.ctl. Now type parameter Key Type.ctl is used both inside the private data of the class and on the fron panel as the Key input, the type of these two must be the same. The same is true for the Value Type element of private data and the Value indicator that both derive from Value Type.ctl type parameter. The has function is any function that can convert any LabVIEW types to some strings that we can use as keys for the variant attribute node. We are using variant attributes as the store implementation is this basic example.
Calling the Dictionary with integer as the type parameter and string as the value would look something like this.
Calling a Type Parametrized Dictionary
As you can see the 0 and empty string will define propagate as type parameter types for Key Type and Value Type in the dictionary wire. Now Add Element.vi would have to adapt to these elections for Key Type and Value Type the moment the Dictionary wire is connected. The Key input immediately change to type INT32 and the Value input to type String. Similar would be true if the wires would be connected in reverse order. Connecting University of Texas string to the Value input of Add Element and connecting number 1 of type INT32 to the Key input of the Add Element would immediately adapt the Dictionary in and Dictionary out inputs to be of type Dictionary[Key Type = INT32, Value Type = String]. A type error would occur if Dictionary in would be of different type.
Type Parametrized Generic Types are an extremely powerful concept to incldue in a language and this idea describes a feasible way to implement them in a visual dataflow model of LabVIEW. This is and has been for maybe ten years my absolute #1 feature I have wanted to see in LabVIEW. I think the time is right for me to officially make this request. Ideally Type Parameters can be bounded but that's a topic for a whole other idea post.
Hi
Is it possible that the contents within the instr.lib to be defaulted to read-only every time LabVIEW launches? VIs that is drag-drop from the pallet onto block diagram is currently modifiable and may cause unintentional code modifications, especially due to the 'save all' function and hasty/improper shutdown. The extend of the damage may be inherited over time.
Also propose to default modified instr.lib VIs saves to be in active project folder instead of the instr.lib.
Hope to see these features in future versions.
Make a tool pallete wizard that would make it easy to install custom software into the tool pallete. It should allow for the user to make the sub directories, Icons and everything that is need so it could be published without have all kinds of headaches. Making tool pallete menus has to be one of the worst things I have to do. This year with the FIRST libraries being added to the tool pallete a lot of them have no icons because of how hard this is. PLEASE make this easier to do!!!!
I would like to see improvements made to LVCompare and LVMerge which allow better git difftool and mergetool integration.
Namely
  • Return/Close process only after comparison or merge are finished
  • Handle both path separators (forward slash "/" and backslash "\") simultaneousely
  • Handle paths relative to calling directory
My tools are technical facing, and I use math.  Instead of ASCII only, a "markdown friendly" version of MathJax, something that allowed me to write clean equations, would be useful.
instead of writing
     "sin(x^2) e1 +cosh(1/x) e2"
I could enter the text
 "$sin\left(x^2\right)\hat{e}_1 + \cosh \left(\frac{1}{x} \right ) \hat{e}_2$"
which is LaTeX in a wrapper
And I would see displayed this:
LaTeX is deep and wide, developed for decades, nicely licensed, and supported well in academia.
Some linkes:
The creation method for Polymorphic VIs is too cumbersome. It is a lot of work to go through each field and manually enter the information; especially if there are lots of data to create. It would be much more time-saving to be able to enter it all in a spreadsheet, and have the creator read from this spreadsheet. People would be much less intimidated to use the creator.
There are some analytic software that adds connections to Excel.  JMP comes to mind - it allows 2-way data transfer, and allows excel to run some of JMP's analysis routines.  Those packaged routines are vetted by phd's and can't be quickly damaged by a tired user.
This details how JP morgan lost a few billion dollars because they were using Excel for hard math, and someone had an error in an equation.
Excel is likely more common than both Javascript or SQL for use in the planet.
It might be very powerful to be able to import an excel spreadsheet, specify inputs, specify outputs, and get it translated to "g".  This could allow it to run thousands of times faster, and the visual language would allow a technical vetting that can be very hard for humans to do on hundreds and hundreds of pages of tables of numbers or formulas.
This would be a motive for banks like JP Morgan (or their peers) and their multi-billion dollar business units to use LabVIEW.  Stunning speed, optimization, and scale.  Stunning accessibility to error correction.  Packages that, once wrapped, stay wrapped, but can plug in where they need to.
Other add-in or connectors for Excel:
It is unlike the TDM-importer in that it sends data to LabVIEW, the data is transformed or processed, and a numeric, text, or image result is returned to Excel.
Labview should support inserting a LabView plot object in microsoft powerpoint to allow access to the data and plot features like enable disable in plots that have been shared via powerpoint. Many other applications support embedding their objects in powerpoint.
GPS/INS applications are increasing every day as you know.
It is inevitable that using maps in GPS/INS project.
There is not a simple and useful map tool in Labview.
In some open source code map applications like "Open Street Map" will be useful for some projects which including GPS/INS.
Currently I use LabView through a Windows VirtualBox on a Linux Mint machine. I was told by a customer support employee that I should bring this idea to this forum. I chose this method because of the limited support for Linux even with the supported distro discs. I encourage NI to expand their Linux-compatible software to have the full capabilities that the Windows and Mac versions do for the distros that are currently out, and to expand the number of distros supported. Linux Mint is one of the most widely used flavors, and yet there is no support from NI.
Back in the NI-CAN days, there was a handy development tool which was the usage of two virtual CAN ports, ports CAN256, and CAN257.  If you wrote a frame on one, it would be read on the other, and vise versa.  Other CAN hardware like Vector, and Kvasar support virtual CAN hardware which does something similar, where initial development can be tested before having access to the hardware.
This idea is to add virtual hardware support for XNET which supports this same feature.  it has been talked about in a thread here several years ago, but nothing ever came of it.  Adding support for virutal hardware for CAN, LIN, Flex-Ray and any other XNET hardware would be a great development tool, and enable the testing of the expected handshaking of software, with simulated communications.
It is possible to import an EPICS .db file into LabVIEW in order to use the Process Variables (PVs) within LabVIEW.
(see https://www.ni.com/en/shop/seamlessly-connect-to-third-party-devices-and-supervisory-system/introduction-to-epics.html )
But, all records are imported as seperate LabVIEW items.
Each PV has to be seperately added as a 'bound shared variable' for inclusion into a VI.
Then each PV will need to be seperately connected up to a control or indicator, unless some means of iterating over the collection is implemented.
This is all fine if there are 3 or 4 PVs (as is the case for the example app).
My current application is quite modest in scope - there are 15 PVs for each of 6 devices, so 90 PVs altogether. It is barely feasible to follow this manual process for each of these - it would take hours and be very finger-trouble prone.
Many EPICS IOCs can use thousands, or even millions, of PVs.
I would suggest that the .db file import wizard process the PVs from each file into a cluster.
Or - possibly better - process PVs into an array of clusters.
IMO, the current implementation just isn't scalable to 'real world' control system IOC use.
If NI wish to provide LV integration with large-scale EPICS projects, I beleieve a better way of doing needs to be found.
(Re-posted from https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Enhanced-EPICS-Support/idc-p/3203 )
It would be really nice is the IDE, and my program were not the same process.
Especially when dealing with 3rd party DLL's, it would really be nice if a bad pointer or misallocated buffer in a DLL didn't crash my whole development environment, but instead just took out the running program.
