Community Browser
Top Authors
Post an idea
Currently, having one misconnected wire breaks the entire wire tree and pressing ctrl+b wipes out everything. Poof!
In the vast majority of (my) scenarios, a broken wire is due to a small problem isolated to one branch so it does not make sense to drag the entire wire from the source to all valid destinations down with it and break everything in the process.
Here is a simplified example to illustrate the problem (see picture).
In (A) we have mostly good code. If we add a wire as shown, that wire (and VI!) must break of course because such a wire would not make any sense.
However, it does not make sense to also break the good, existing branches of the wire (the cluster in this case), but that is exactly what we get today as shown in (B). If we press ctrl+b at this point, all broken wires will disappear and we would have to start wiring from scratch (or undo, of course :)). Even the context help and tip strip is misleading, because it claims that the "source is a cluster ... the sink is long ...", while that is only true for 25% of the sinks in this case!
What we should get instead is shown in part (C). Only the tiny bad wire branch should break, leaving all the good connection untouched. Pressing ctrl+b at this point should only remove the short bad wire.
The entire wire should only be broken in cases where nothing is OK along its entire length, e.g. if there is no source or if it connects to two different data sources, for example.
Summary: Good parts of a wire should remain intact if only some of the branches are bad. Wires that go to a destination compatible with the wire source should not break.
(Similarly, for dangling wires, the red X should be on the broken branch, not on the good source wire as it is today)
Implementation of this idea would significantly help in isolating the location of the problem. Currently, one small mistake will potentially cover the entire diagram with broken wires going in all directions and finding the actual problem is much more difficult than it should be.
When wiring a numeric or enum to a case structure, we get the existing case as 1 (or the second enum item) and a default case also containing "0" (or the first enum item). Many times we need a special case only for one item and everything else should be in the default case.
Case structures are happy with just the word "default" in the second case. The unfortunate automatic existence of one other specific selector value in the default case hampers workflow. For example in the vast majority of my coding, I want the special case to be zero and the other case to be the default.
After wiring the selector, I could just enter the desired value in the non-default case that is showing, except if that desired value also exists (for no good obvious reason!) in the default case. If this happens, I need to edit the default case. That should not be necessary.
Suggestion: Whenever a default case is automatically created, it should not contain any extra specific selector values.
There seem to me to be a couple of choke points in right-click access to VIs and functions.  One is that I frequently need to use the same VI's repeatedly.  Another is that the quite useful "insert" and "replace" context items only offer a few first-tier options: one or two related palettes, or all palettes.  Try to insert a few datalog functions for example, and you have to navigate down 6 levels for each. It's even worse if you have to use "select a VI..." and browse to it. For the worst cases, insert and replace lose their advantage over copy-paste or quick drop.
 I propose a dynamically generated palette consisting of the last several VIs and functions (even controls) that have been dropped.  This is analogous to recent-commands-list functionalities common in CAD packages.
- As a member of the functions palette, the items in it are at or above the level they are in their normal place in the hierarchy.
- Since it's a palette you could pin it and it would be handy for dropping the same node on two different block diagrams
My idea is to have LabVIEW cease and desist it's self-important modal behavior.  Not that I think LabVIEW is anything other than the most important application I run, but I don't think it should force its (many windows') way to the front of the line when I shift focus to a LabVIEW window.  I didn't find any other idea that matched this, but there is this discussion that covers the notion well.
An example case:  When chasing efficiency I frequently have Task Manager open to observe CPU usage when I change front panel controls.  I'll run the .vi and load Task Manager, but when I click on a front panel control ALL the LabVIEW windows come to the front and cover Task Manager:Modal.png
So, my suggestion is to have only the selected LabVIEW window come to the front.  I get the impression that Ctrl-Tab and Ctrl-e behavior are why LabVIEW controls its own window z-placement, but leaving their function out of it, my suggestion is just to change the modal behavior of LabVIEW windows.
It would be nice if you could change a selected font style by using the standard windows (MS office) shortcuts, such as CTRL-B for bold and CTRL-U for underline.  This would save many mouse clicks.
I realize that many people don't use Windows, so maybe it could be customized in the .ini file or would be dependent on what OS your are running.
When you connect the error wire to a case structure selector, you get two cases for error and no error. I think you should be able to add in cases for specific error numbers so you can handle specific errors differently. You could do this currently, but you would have to unbundle the error and use the error code.
It would be nice if NI added "Mouse Scroll" (and its counterpart filter event) to the supported events. Today, you can do this by using the mouse input VIs in a separate loop and polling, but that's not a very nice solution.
The default LabVIEW environment option should not show terminals as an icon.
The "Probe Display" pane of most default probes should have indicators that are set to "Fit to Pane". The worst offenders, in my opinion, are Strings and Variants...I often find myself cursing the fact that I can't see more of the data, and usually have to copy & paste into Notepad++ or something to actually see what I'm looking for.
Yes, you can make custom probes for this behavior. But it should be native.
Currently text in an "unbundle by name" node is centered. This makes for poor readability when there are several elements being unbundled.
I think that changing the justification from center to left does improve readability.
Note 01: This apply to bundle by name as well.
Note 02: implementing this idea my gave us this one for free.
It'd be usefull for develloper and especially application user to improve graph control by adding to Graph direct access to Plot Visible property on plot legend.
For the time being, you have to go to color and choose transparent or to change visible property dynamically.
I propose control like that ... but we could find another idea to access Visible property.
All plot visible Selected plots visible
Current Situation
The current commenting practice in the BD is to place free floating comment number labels and write the comment in a text field as in the example below.
Disadvantages
- comment number labels do to stick to the code block. if the code number block is moved the comment has to be moved as well.
- no link between number and comment text block
This unsophisticated way of commenting LabView code lead to the lack of comments in general. Usually a new programmer can understand what happens, but not why a function is implemented like this.
Proposal
LabView provides the Advanced Code Commenting Functions.
The comment block is more then just a text block. Basically it has a comment ID, the comment itself and a comment category.
By the context menu the following functions are provide:
  1. add comment
  2. delete comment
  3. move comment up
        The particular comment line is moved up in the comment block. The ID is decremented
  4. move comment down
         Opposite from 3.
  5. highlight function
         The function to which the comment ID sticks is highlighted.
  6. the comment category can be selected. (e.g.. Code Explanation, To Do, )
Adding Comments
Adding a comment in the comment block incorporates two steps (after selecting Add Comment from the context menu):
1. Sticking the automatically generated comment ID to a particular code block just by selecting the item the comment belongs to.
   This could be any type of code: wires, SubVIs, the whole Case, a particular Case, Sequences....
2. Writing the comment
If the mouse pointer is set over a comment ID the comment is shown like a tool tip and disappears as soon as the mouse is moved away.
Advantages
  • Comment moves with function block if function is moved on the BD
  • Comment ID sticked on the BD item and ID on the comment block always match
  • generally more comments in a LabView programm through more simple way of commenting code
I started a discussion here
Although the suggestion about using a template is quite nice, I would still like to be able to create a new VI (or sub-VI) from within a project.  I never use the default icon provided by NI.  -- N-E-V-E-R --   That's a personal choice.
So since I never use that icon, the fact that creating a new VI which auto-generates an icon that is never used, renders that feature useless.  Let's see how many users of LabVIEW also find the default icon useless....  (Kudos would be a way to take a poll).
A nice feature would be to allow the developer to create her / her own default icon.  The default icon is probably somewhere in the ini file (I have not checked).  One of the Options could be to select if the user wants to use their own default, and if so, browse to the icon or have an editor create one.
In my case, when creating a new VI, it ends up with a icon like this:
I would be happy to have a default icon that looks like this:
The idea I am proposing is that developers should be able to have the icon of their choice as a default icon.
And may plenty of kudos adorn this thread..  🙂
Spoiler
I would be surprised if this is not a duplicate but I was unsuccessful finding it.
The subject says it all. Simply add a scrollbar to free text labels. I sometimes use a string constant for free labels simply because they can have a scrollbar.
I could be easier to insert or delete element from array by only select and hit Insert or Delete on keyboard.
Insead of this:
Select like this:
Title says it all. Have a slider or pull-down that increases or decreases the highlight execute rate.
Automatic routing of new wires is actively trying to get in my way!
Automatic Wire Routing
I can add a manual bend and try to pixel align things myself then clean up mistakes after, but why can't it work right the first time!
When an array leaves a loop with indexing enabled, you get an array which has one more dimension, but quite often you want to concatenate the data to an array with the same number of dimensions.
If the subarrays have the same length, you can use reshape array, but usually they don't and you need to do something like below.
It would be very useful if output tunnels for arrays had an "Enable Concatenate Indexing" option as well, as depicted below, which would do this.
More often than not, one location doesn't work for both. Here's an idea:
I would love to be able to draw a box over a bit of code on the block diaghram and be able to highlight execution just for what's in the box. The rest of the code should execute at full speed. This frequently becomes an issue when you are trying to track down a bug in a big program and you've got to wait for ages to get to the bit your interested in.
