Upconvert VI Requests
@signal generator wrote:
Hi Andew
I think I need the whole LabVIEW Library Files to be updated, I just can't open them on my computer with my LabVIEW version now.
Thanks you so much!!
see here: http://forums.ni.com/t5/LabVIEW/Upconvert-VI-Requests/m-p/1305534#M537410
Message 1041 of 1,261
(1,397 Views)
Need this in 8.2 version !!
Lot of thxs
Message 1042 of 1,261
(1,392 Views)
@smercurio_fc wrote:
@Dennis Knutson wrote:
@clihunc wrote:
I would like to control the Agilent E3631A power supply but was not able to open this file with LabView 2011.
Could someone please help me to convert this file?
The source is in LabView 5.1 and what I need is LabView 2011.
Thanks!
Why would you go out of your way to find it and then want to use that code when a current driver is available from NI? Tools>Instrumentation>Find Instrument Drivers
Thanks for spotting that Dennis. Sometimes I get into automatic mode with these upconversions...
Thanks for the help, smercurio and Dennis. Actually I wrote one based on the driver given in the NI website. But the old one was written by someone in our lab long time ago and I just want to check if there is some special function I need to add to my own program:D
Message 1043 of 1,261
(1,368 Views)
Thanks!
attache is in 8.2. The code is quite poor and I suggest rewriting it.
Sorry for bothering you again, smercurio. I am trying to control the ISA TRIAX 550 and ISA SPECTRACQ2. But the latest version of Labview code I can find on Internet is 4.0.2 :(. Can you please help me converting this to Labview 8.2? There are two .llb files. Can you please convert all the .vi files in both .llb files?
Much appreciated!
Message 1044 of 1,261
(1,349 Views)
Hello !
Need This vi in version 8.2 plz !!
Message 1045 of 1,261
(1,343 Views)
@Oriolba wrote:
Hello !
You've already asked for this in this thread and in your original thread.  Please learn some patience.
And also post in the correct thread. You are asking for a downconversion. Downconversions go into the Downconvert Requests Thread.
Message 1046 of 1,261
(1,335 Views)
Much appreciated!
attached
Message 1047 of 1,261
(1,334 Views)
I have bought the keithley acquisition card KPCI-3102 which works with labVIEW 5. Now I have bought the version 9 of LabVIEW and I want to use it to work the card. But, with the driver in the next link I have the compatibility problem, because the driver is too older (LabVIEW version 5) to convert it and works in the new version 2009.
Can you please help me to convert this LLB from LabVIEW 5.0 to LabVIEW 9? I would really appreciate it!
Thanks in advance.
 http://www.keithley.com/base_download?dassetid=6082
Message 1048 of 1,261
(1,318 Views)
Thanks in advance.
Message 1049 of 1,261
(1,316 Views)
Thanks in advance.
You did not need to post this question again 10 minutes after your first request. Please be patient. Most (if not all) of the volunteers here have full-time jobs.
As for your request: that is an executable. You need to run the installer in order to get the drivers. I certainly have no intention of doing this. If you wish to have the libraries updated then post the actual  .LLB files (or whatever the installer installs).
Message 1050 of 1,261
(1,312 Views)
