Community Browser
Post an idea
This topic keeps coming up randomly.  A LabVIEW class keeps a mutation history so that it can load older versions of the class.  But how often does this actually need to be done?  I have never needed it.  Many others I have talked with have never needed it.  But it often causes problems as projects and histories get large.  For reference: Slow Editor Performance with Large LabVIEW Projects Containing Many Classes.  The history is also just added bloat to your files (lvclass and any built files that use the lvclass) for something most of us do not need and sometimes causes build errors.
My proposal is to add an option to the class properties to keep the mutation history.  It can be enabled by default to keep the current behavior.  But allowing me to uncheck this option and then never have to worry about clearing the history again would be well worth it.
Background
The DAQmx apis allow streaming measurements to TDMS. This supports spanning multiple files (by setting the max file size for individual files in the span set), which is very useful.
We need a similar feature for files we're writing to directly (i.e. not using DAQmx) with the TDMS File functions in LabVIEW.
Note: The main reason we wanting this feature, right now, is that our files are growing quite large and when we run the TDMS Defragement function, we get out of memory errors in RT on cRIO (e.g. if we have 512MB RAM on our cRIO and the TDMS file is around the same size).
Alternatives
We're thinking to do this ourselves, however the TDMS file api does not support checking the file size from a TDMS file reference  (and that's a great idea, too).
I'm not totally sure how this would be added to the TDMS file api -- maybe there could be a "TDMS Advanced Spanning" palette with options for configuring and interacting with TDMS spanning.
Currently, the TDMS File api does not offer a way to get the TDMS file size.
Our use case is that we'd like to limit the size of the TDMS files and span them accross multiple individual files (and I've posted an idea suggestion for adding that as a native feature, too).  To do this, we need to be able to monitor the TDMS file size, so that we can save/close the current file and then create the next file in the span for continued use (until we hit the size limit again).
I like channel wires for obvious reasons. I like to have modules, which work on their own, coming with their own GUI. This is convenient for developing my modules and testing them. Afterwards I want to be free to insert this module into a bigger project, which takes control of my module.
The channel wire controls on the connector pane can be set optional, but LabVIEW throws an error, when executing a VI with not connected channel wire control. (All branches of a channel wire must be connected to a channel endpoint...)
Please make VIs working with not connected, optional channel wire controls on the connector pane. That way, we can have channel wire based modules, which can run on their own, as a single VI, or can be controlled remotely without any change.
The compare tool is fundamentally broken which is somewhat shocking considering that such a tool is essential to any sort of large scale or long term software development.
Attached is a basic LV 2023 example which illustrates some of the many flaws with the tool.  If you compare "old version" and "new version" vi without including cosmetic changes, the tool shows 33 differences, most of which are incorrect.
Timed Loops are only supported on Windows and RT, making it difficult to port applications that use it to Linux.
In talking to some NI R&D people, it should be possible to port the RT Linux shared library to desktop Linux. (Perhaps it wouldn't even need to be recompiled, since it's x86.) We also need support in the editor on Linux to allow us to drop the structure.
This seems like low-hanging fruit to at least try to implement.
Current Behavior:
When using the "retain all errors" option of the Merge Errors function the combined error message JSON output is not a valid JSON string.
This is the source output of Merge Errors when retain all errors is active - it is not a valid JSON string.
<JSONErrorMultiple_1.0>[{
    "status": true,
    "code": 111,
    "source": "This is a test message including\nnewlines"
    "status": true,
    "code": 222,
Desired Behavior:
Make the combined errors source string a valid JSON string so that it can be parsed by other tools.
Valid JSON string:
[{"status":true,"code":111,"source":"This is a test message including\nnewlines"},{"status":true,"code":222,"source":"This is a test message including\nnewlines"}]
 The above JSON string can be formatted nicely by most tools - e.g. JSON pretty print - https://jsonformatter.org/json-pretty-print
The below string including the JSONErrorMultiple_1.0 key (but formatted correctly) also works:
{"<JSONErrorMultiple_1.0>":[{"status": true,"code": 111,"source": "This is a test message including\nnewlines"},{"status": true,"code": 222,"source": "This is a test message including\nnewlines"}]}
When looking for unexpected behaviour in time or memory usage of a project the Profiler is useful and easier than the execution tracer, but it could be made much more useful by adding the ability to monitor for changes and analyse the issues.
Issue:
Currently detecting how the memory or run counts e.g. of a VI changes over time you have to take snapshots, save them and then compare the values in e.g. Excel. (which the saved traces do not directly fit into either...)
Proposed feature: Trends
It would be nice if you could just set the tool to automatically sample and log all/selected numbers regularly and then be able to view the trends.
Proposed feature: Automated Analysis
Having trends will help in manually detecting issues, but the profiler could also have tools that helped you in this, e.g. highlighting which VIs show a continous growth in memory. This could also then be expanded by being able to call a VI analyzer on any given VI - preferably made/set up to identify possible reasons for a memory leak e.g. (unclosed references, continous array building e.g.).
Using 2023 for the first time (skipped 2021 and 2022)
QuickDrop used to be quick.
It was very convenient.
Now it takes a second to load.
That's pretty inconvenient if you're trying to... do much of anything.
Best example: If you're trying to remove code (Quickdrop's Control-R), now instead of quickly removing the selected code, you get to deal with accidentally RUNNING your VI (Menu's Control-R)
Please make it Quick again
It would be helpful to add an option like "Digital Value" in the DAQmx Trigger.vi (comparable to Analog Window).
Background: when missing the edge of a digital trigger signal (due to being late in code execution after eg. waveform reconfiguration), the trigger event does not happen. With this new option it is possible to execute the trg event asap after missing the edge.
It would be great to be able to configure LVMerge options via the command line as described here
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q0000019c3VCAQ&l=en-US
There was a previous proposal to fix this that was closed
https://forums.ni.com/t5/LabVIEW-Idea-Exchange/LVMerge-Configurable-Load-Options/idi-p/1282252
Please kudos this so that that it is considered 😉
Many times, at least in my codes, it's necessary to act only on a rising / falling or changed edge of a boolean signal.
Probably this option can be added for CASE-structures with a boolean-type case selector of cause.
It would be better if we could probe the auto indexed tunnel while the for loop is still executing.
If the For Loop is running for a huge number of iterations and if the Auto-indexed tunnel is having a condition. Then to check the values in the conditional auto-indexed array should be made possible even when the for loop is still running for debugging purpose.
If something like the below can be done it will be helpful in debugging.
Hi
While working with LabVIEW I would suggest that there are broken arrow that shows that the code is not complete if we left to wire any input or output.
I would suggest that there should be an option in the block diagram that we can select the active region (it could be as to draw box) and LabVIEW should only consider code that is inside the box and outside of the box if any unwired input  or output should be ignored.
I hope  I made my idea clear.
Asif
It would be useful to add a Boolean for resetting "First call?". Sometimes it might be required to reset a first call during a run.
It could be as following:
Many of these VI properties are "Run-time" writeable.  They should not be set while the vi is in an "Idle" state
LabVIEW crashes randomly when network functions are used on Linux. This problem appears especially when many connections or files are open.
R&D has identified the issue but is evaluating wheter or not the issue will be resolved in future releases.
All the details are here :
https://forums.ni.com/t5/LabVIEW/TCP-Allow-files-descriptors-gt-1024/m-p/4297433#M1255356
An example is attached.
It would be nice to easily find objects that prevent a structure with "Auto Grow" from becoming smaller in size.  For example, the Add function in  the True case in the simplified example below.
I have a large base of compiled executables. One computer is encountering a "not enough memory to complete this operation" error. I'd like to drop a debug version of the executable on their computer and see if I can monitor which VI is using all the memory similar to DETT's remote monitor abilities.
Sometimes, when debugging code, I may force a situation, e.g. force a boolean to be TRUE or FALSE, or force a For Loop to only run once. Once I have made the fix I then forget to reverse my changes and run my code. Or, even worse, create an executable and send it to a customer. Doh!
Could we create a primitive, in the shape of a small bug, that I could drop in my code at the point where I force the code? Then, when I come to run a popup asks "Run with bug?" This would allow me to debug my code, but would also remind me to undo the deliberate bug before I run the code for real or try to create an executable.
