NI-488.2 installation issue for windows 7
I already  have labview2013 64bits
but here https://forums.ni.com/t5/Reference-Design-Content/LabVIEW-Modbus-API/ta-p/3524019
Requirements
Software
LabVIEW 2012 or later
NI-VISA for Modbus serial communication"
Message 41 of 86
(2,764 Views)
So what is the question? You said you had installed NI-VISA as well.
Message 42 of 86
(2,759 Views)
is this library compatible with labview x64 or I need to install x32 ?
Message 43 of 86
(2,756 Views)
As far as I know, it should be okay but I haven't tried it.
Message 44 of 86
(2,750 Views)
no it is not working , it is not compatible , check the piece jointe
Message 45 of 86
(2,743 Views)
That means you have to do what the message says in order to enable vipm. It's a setting issue.
Message 46 of 86
(2,739 Views)
hi thx
I fixe the setting issue and I  installe the mobdus librery but about the diagramme how can I use the fonction "visa configure serial port " cause I need to indicate "the parity/ the baud rate /the data bit... , and at the same time using the "MB serial master holding register" to specify the "starting adress/ quantity/ the code fonction(holding register)...
I'm already searching for closing example
can you help me
Message 47 of 86
(2,710 Views)
The manual for your device should provide the communication settings you need to set as well as a list of the registers.
Message 48 of 86
(2,706 Views)
sorry I don't understand your answer can you clarify plz
thx
Message 49 of 86
(2,701 Views)
You asked what to set the baud rate, parity to and I answered that settings would be in your manual. You asked what registers to read and at what addresses. I answered that the information would also be in your manual. What is confusing about rtfm? I don't have it, you do. I don't know what device you have, you do.
Message 50 of 86
(2,698 Views)
