NI-488.2 installation issue for windows 7
no it is not unstalled
Message 31 of 86
(2,930 Views)
so I need to install it too ?!
Message 32 of 86
(2,927 Views)
This is what happens when you hijack an old thread and say you have the same problem. The thread topic refers to 488.2 and now you say you are only using serial. A lot of time wasted. For serial, you only need NI-VISA and you only need NI-Serial if you are using an NI USB-RS232 converter. The previous answer is not correct if you aren't. Please provide full information.
Message 33 of 86
(2,912 Views)
Ok since you were on this thread I assumed your problem was similar to the one on this thread. I was wrong so lets start over again.
What type of Hardware interface are you using? Such as PXI, USB,
What type of specific Hardware are you using? Such as USB-RS232-4
What OS are you using? Such as Windows XP
What type of Software are you using and what version? Such as LabVIEW, Python
What is it that you are trying to do?
Message 34 of 86
(2,907 Views)
yes Im sorry but I didn't understand what s the ni 488 drivers also I don't understand all the answers and the topic of the forums cause the english not my language mother
Yeah I m using usb / rs232 converter , do the ni serial and the ni visa must has the same version  ?
Message 35 of 86
(2,906 Views)
You need to specifically answer the following question otherwise its a waste of time
1. What type of Hardware interface are you using? Such as PXI, USB,
2. What type of specific Hardware are you using? Such as USB-RS232-4
3. What OS are you using? Such as Windows XP
4. What type of Software are you using and what version? Such as LabVIEW, Python
5. What is it that you are trying to do?
Message 36 of 86
(2,897 Views)
ok , I m using windows7 x64
the type of convert is  U232-P9
labview 2013
I try to create a communication between the labview interface and a system that is send the data with the modbus RTU but I don't have port rs232 in my pc so I use the convert usb/rs232
Message 37 of 86
(2,886 Views)
For the last time, you do not need NI-Serial. You need the Windows driver that came with the device. You would then need to install NI-VISA. The latest is at https://www.ni.com/en/support/downloads/drivers/download.ni-visa.html#306022
If you have installed the Windows driver, your port will be shown in Windows Device Manager. Once you install VISA, your port should appear in Measurement and Automation Explorer.
Message 38 of 86
(2,869 Views)
the ni visa driver was installed 🙂 thx
Message 39 of 86
(2,861 Views)
And for Modbus, there is a LabVIEW api at https://forums.ni.com/t5/Reference-Design-Content/LabVIEW-Modbus-API/ta-p/3524019
You can also use DSC toolkit for Modbus.
Message 40 of 86
(2,848 Views)
