04-27-2015 10:56 AM
no it is not unstalled
04-27-2015 10:58 AM
so I need to install it too ?!
04-27-2015 11:37 AM
04-27-2015 11:44 AM
Ok since you were on this thread I assumed your problem was similar to the one on this thread. I was wrong so lets start over again.
What type of Hardware interface are you using? Such as PXI, USB,
What type of specific Hardware are you using? Such as USB-RS232-4
What OS are you using? Such as Windows XP
What type of Software are you using and what version? Such as LabVIEW, Python
What is it that you are trying to do?
04-27-2015 11:48 AM
yes Im sorry but I didn't understand what s the ni 488 drivers also I don't understand all the answers and the topic of the forums cause the english not my language mother
Yeah I m using usb / rs232 converter , do the ni serial and the ni visa must has the same version ?
04-27-2015 12:03 PM
You need to specifically answer the following question otherwise its a waste of time
1. What type of Hardware interface are you using? Such as PXI, USB,
2. What type of specific Hardware are you using? Such as USB-RS232-4
3. What OS are you using? Such as Windows XP
4. What type of Software are you using and what version? Such as LabVIEW, Python
5. What is it that you are trying to do?
04-27-2015 12:11 PM
ok , I m using windows7 x64
the type of convert is U232-P9
labview 2013
I try to create a communication between the labview interface and a system that is send the data with the modbus RTU but I don't have port rs232 in my pc so I use the convert usb/rs232
04-27-2015
02:07 PM
- last edited on
11-02-2025
11:00 AM
by
Content Cleaner
For the last time, you do not need NI-Serial. You need the Windows driver that came with the device. You would then need to install NI-VISA. The latest is at https://www.ni.com/en/support/downloads/drivers/download.ni-visa.html#306022
If you have installed the Windows driver, your port will be shown in Windows Device Manager. Once you install VISA, your port should appear in Measurement and Automation Explorer.
04-27-2015 04:51 PM
the ni visa driver was installed 🙂 thx
04-27-2015
07:26 PM
- last edited on
11-02-2025
11:01 AM
by
Content Cleaner
And for Modbus, there is a LabVIEW api at https://forums.ni.com/t5/Reference-Design-Content/LabVIEW-Modbus-API/ta-p/3524019
You can also use DSC toolkit for Modbus.
