04-30-2015 06:13 PM
my device is a relai multifonctions (rs-485 modbus rtu) , I will control it from my labview interface
04-30-2015 07:37 PM
04-30-2015 07:41 PM
05-01-2015 06:34 AM
the device is The LUCM or LUCMT multifunction control units perform the following protection functions:
 Protection against over-currents (protection not provided by LUCMT)
 Protection against thermal overloads, with choice of trip class from 5 to 30
 Protection against ground faults
 Protection against phase imbalances
 Protection against mechanical jams during or after the start-up phase.
 Protection against idling
 Tripping of the starter via an external signal (as an option)
The protection,functions may be configured and monitored:
Locally, using the built-in display and keyboard
Remotely, using:
 An RJ-45 communication port, Modbus RS 485
the relai has a registers, and each register contains the parameter that we will controlled it
in the company they use rs485/rs232 converter to connect it to the pc , but in my own pc I don't have rs232 port so I use an adapter rs232/USB
05-01-2015 07:23 AM
05-01-2015 07:36 AM
why ? what's wrong with it?!
05-01-2015 07:47 AM
05-01-2015 08:01 AM
yes I understand the difference very well , there is a converter rs232/rs485 to connect it to the pc , in the company they has used this device with the logiciel modscan and it works very well ( they can read the data using the converter),now the company need to provide this issue using labVIEW so my project is to create a labview interface for reading the data contained in the relai but I do not have the port rs232 so I use rs232-USB converter
05-01-2015 08:18 AM
05-01-2015 09:12 AM
my question was how can I rely the visa fonction with the MB serial Master query , as well as the class of my USB is USB RAW so I changed the visa class i/o session from usb instr to usb raw , yet the error was appear plz check the piece joint
