NI-488.2 installation issue for windows 7
hi
i was cliking
Message 71 of 86
(1,996 Views)
Why are you showing the block diagram for test2 but the front panel of a subVI? One problem at a time. Open the init function, run it. Show what you get. Open MAX and configure the serial port. Show what you get.
Message 72 of 86
(1,980 Views)
Hi Dennis
I show the front panel of a subVI cause I think that the pb it comes from it,
 take  a look to the pic bellow
Message 73 of 86
(1,974 Views)
here the rest
Message 74 of 86
(1,971 Views)
I'm afraid that I don't understand what the problem could be. The error code indicates that NI-VISA is not installed correctly yet MAX does not indicate the same error. What version of.VISA is installed?
Message 75 of 86
(1,945 Views)
Message 76 of 86
(1,937 Views)
Message 77 of 86
(1,944 Views)
Try installing the latest version instead of the oldest one.
Message 78 of 86
(1,933 Views)
yes I install the ni visa 1401 , but it figure this msg in error out of MB serial master query read holding register:
"VISA Write in MB Serial Transmit.vi:630002->MB Serial Master Query.vi:1850001->MB Serial Master Query Read Holding Registers (poly).vi"
what does that mean ?
Message 79 of 86
(1,923 Views)
with this code "-1073807346''
Message 80 of 86
(1,922 Views)
