NI-488.2 installation issue for windows 7
You are making less sense. The class should NOT be USB RAW. If you correctly installed the converter software and VISA it should be a Windows com port. USB RAW implies you used the VISA Wizard and that is just the wrong thing to do.
Message 61 of 86
(1,856 Views)
Message 62 of 86
(1,848 Views)
Why would you do that? That tutorial is meant to be used when you don't have a driver for the usb device and when you have complete information from the vendor on the RAW protocol. You will never get the modbus library to work by using RAW. You've broken everything. Undo everything you did and install the Windows driver for the converter that came with it. Don't post back until you have a com port in device manager and in MAX so that you can start from the correct place.
Message 63 of 86
(1,843 Views)
oh my god !! I already do that cause my professor doesn't  pay attention about my project I'm working alone 😞
Message 64 of 86
(1,831 Views)
Use a system restore point or delete the inf and pnf files that were created by the wizard.
Message 65 of 86
(1,827 Views)
Hi
the prob is solved thx 🙂
Message 66 of 86
(1,793 Views)
can help me to find the french version of this page http://www.ni.com/white-paper/14689/en/#toc1
Message 67 of 86
(1,789 Views)
Please start a new thread for this totally unrelated question. And use the correct board - http://forums.ni.com/t5/LabVIEW-Web-UI-Builder-and-Data/bd-p/480
Message 68 of 86
(1,783 Views)
hi
I connect the usb port and I l  have a com port in device manager and in MAX
now when I run the interface the fonction MB serial master query read holding register have a error in and error out
plz check the pic bellow
Message 69 of 86
(1,759 Views)
You don't show the init function but you can clear the error in by simply clicking on the Boolean checkmark to see if it goes away.
Message 70 of 86
(1,744 Views)
