NI-488.2 installation issue for windows 7
my device is a relai multifonctions (rs-485 modbus rtu) , I will control it from my labview interface
Message 51 of 86
(1,770 Views)
Which should have come with a manual that you need to read. Surely you know the make and model. You haven't provided that so how can anyone answer your questions?
Message 52 of 86
(1,760 Views)
And how do you think you can communicate to an RS485 device if you have an RS232 converter? They are different!
Message 53 of 86
(1,757 Views)
the device is The LUCM or LUCMT multifunction control units perform the following protection functions:
 Protection against over-currents (protection not provided by LUCMT)
 Protection against thermal overloads, with choice of trip class from 5 to 30
 Protection against ground faults
 Protection against phase imbalances
 Protection against mechanical jams during or after the start-up phase.
 Protection against idling
 Tripping of the starter via an external signal (as an option)
The protection,functions may be configured and monitored:
Locally, using the built-in display and keyboard
Remotely, using:
 An RJ-45 communication port, Modbus RS 485
the relai has a registers, and each register contains the  parameter that we will controlled it
in the company they use rs485/rs232 converter to connect it to the pc , but in my own pc I don't have rs232 port so I use an adapter rs232/USB
Message 54 of 86
(1,742 Views)
Well, you bought the wrong adapter if the device is RS485.
Message 55 of 86
(1,735 Views)
why ? what's wrong with it?!
Message 56 of 86
(1,730 Views)
It's RS232 and you just said the device requires RS485. Don't you understand the differences? Please do some basic research.
Message 57 of 86
(1,727 Views)
yes I understand the difference very well , there is a converter rs232/rs485 to connect it to the pc , in the company they has used this device with the logiciel modscan and it works  very well ( they can read the data using the converter),now the company need to provide this issue using labVIEW so my project is to create a labview interface for reading the data contained in the relai but I do not have the port rs232 so I use rs232-USB converter
Message 58 of 86
(1,722 Views)
So you have a separate RS232 to RS485 converter as well? That was not clear from your posts. I don't understand where you are stuck now. The modbus spi for LabVIEW contains all of the functions for setting address to read and returning the register content.
Message 59 of 86
(1,717 Views)
my question was how can I rely the visa fonction with the MB serial Master query , as well as the class of my USB is USB RAW so I changed the visa class i/o session from usb instr to usb raw  , yet the error was appear plz check the piece joint
Message 60 of 86
(1,710 Views)
